Orion 400 BDG
mexi
Copper - Posts: 156
Posted: June 12, 2006 at 11:02 PM / IP Logged
Anyone know how to hook up one of these modules? I am using it with a 4 channel hcca amp its rated at 4x25
mexicang
haemphyst
Platinum - Posts: 5,054
Posted: June 13, 2006 at 8:17 AM / IP Logged
RCA in, 5 pin DIN cable to input of ONE of the pairs... That's all there is to it. It gets it's power from the power supply of the amp, over the DIN cable. If you want to bridge all 4 channels to 2 channels, you need two of those 400 BDG's. That part allows bridging of one pair only. Also it will only work with the early generations of Orion amps - look for the DIN input on the end of the amp, otherwise the newer ones without the DIN connection are already bridged internally...
04mdx4sq
Copper - Posts: 111
Posted: June 20, 2006 at 4:03 PM / IP Logged
Actually, it is only needed for first generation amps, I believe only the amps with the first Orion logo on a sticker needed them, the DIN plug continued through the second and third gen amps. If it has the machined in logo it likely does not need the bridging module(s).
04 MDX - Clarion DRZ9255 / MB Quart QAA4250 / MB Quart QSD216 / Orion Concept 97.2 / JL Audio 10w6v2
91 GMC Syclone - Delco tape deck
90 Syclone powered 2wd S10 (for sale) - Pyle CD / Fosgate 4x6
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
