memphis audio rca
hshark
Member - Posts: 9
Posted: July 11, 2007 at 1:39 AM / IP Logged
ok so i have 17' rca's but i want to connect them for a distance much less than 17' more like 5-6' will this cause noise or problems? i have a hatch so my amps(3) are close buy or should i go and get some shorter ones? i think the extra length may cause problems but then again its memphis.. thanks!
memphis car audio all around
jmelton86
Gold - Posts: 1,228
Posted: July 11, 2007 at 2:50 AM / IP Logged
The only problem, if it would be to you, would be a slight time delay compared to your other speakers in the car.
Go ahead and get some shorter ones, though. Try to get all of your RCA's in the same lenth, as long as the furthest amp from the HU needs. This way you're good to go.
'but then again its memphis..' I like that!
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
