speaker problems
zakives
Member - Posts: 9
Posted: September 18, 2007 at 5:23 PM / IP Logged
i was recently working on my rear speakers in my trunk when the speaker wire fell and touched a wire connected to my amp.  My speakers made a loud noise and now no noise whatsoever comes out of them. any ideas of how to fix?
ZaK Ives
jmelton86
Gold - Posts: 1,228
Posted: September 18, 2007 at 5:57 PM / IP Logged
The rear speakers are powered by an amp? Model #'s of everything involved is nice. Do you know exactly which wire hit where?
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
zakives
Member - Posts: 9
Posted: September 18, 2007 at 8:11 PM / IP Logged
no rear speakers are not powered by amp . i had a loose connection in my left speaker so i went into my trunk to put a barrell clamp on the wire and it fell and touched where the speakerwire connects to teh amp. amp still powers up and subs still work but no sound at all from front or rear speakers.  i thought they could of been blown but there is no distortion and no sound at all
ZaK Ives
dpaton
Copper - Posts: 141
Posted: September 18, 2007 at 11:35 PM / IP Logged
Sounds more like the amp took the hit, not the speaker.
This is not a sig. This is a duck. Quack.
tcss
Silver - Posts: 1,623
Posted: September 18, 2007 at 11:42 PM / IP Logged
Possible that the deck protection circuit kicked in. Try resetting the deck. If this doesn't help, I suspect you have hurt the outputs on the deck and it needs to be serviced.
There is no such thing as free installation!
kassdog
Copper - Posts: 257
Posted: September 19, 2007 at 2:22 AM / IP Logged
Do you get sound out of the fronts. If you do you might have blown the amp in the deck.
zakives
Member - Posts: 9
Posted: September 19, 2007 at 1:22 PM / IP Logged
no there is no sound from front or rear speakers
i will try reseting the deck
ZaK Ives
zakives
Member - Posts: 9
Posted: September 19, 2007 at 1:25 PM / IP Logged
reset the deck and still no sound what should i do from here?
ZaK Ives
zakives
Member - Posts: 9
Posted: September 19, 2007 at 1:26 PM / IP Logged
and i dont think it hurt my amp because my subs are still getting full power
ZaK Ives
sarcomax
Copper - Posts: 276
Posted: September 21, 2007 at 12:59 PM / IP Logged
What kind of deck do you have? How did you reset it? Was there a reset button or did you just disconnect the power? Most aftermarket radios have protection circuits for just such an occurance, however I do not know if that is the case with factory setups. It sounds like you probably fried something in the deck. If you have more than one set of preouts you can always get a four channel amp for your other speakers...
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
