speaker problems, 93 grand caravan
hancteacher
Posted: October 26, 2007 at 10:35 AM / IP Logged
I have a 1993 dodge Grand Caravan with an Infinity speaker system. A number of years ago the factory installed tape deck stopped working. I purchased a new Jensen (I think) tape deck and was having trouble getting all the speakers to function properly. I recall cutting a few wires by the speakers and everything started working great. After a few more years that tape deck stopped working so I purchased an original chrysler tape deck that was compatible with the original. It also worked fine. Now I purchased (on Ebay) 2 Chrysler tape/cd players and on each one I can't get the frony speakers to work. When I install the non cd player the front speakers work. I am pretty sure that the problem is not with the unit but with the speakers. I still have unconnected cut wires around the speakers but I can't seem to pinpoint the problem. Any ideas?
hancteacher@juno.com
KarTuneMan
Platinum - Posts: 7,056
Posted: October 27, 2007 at 1:57 PM / IP Logged
Identify these wires behind the deck. strip 1 pair back. Get a 9v battery and touch the wires to the battery. The speaker "should" pop. Now you know the speaker works. Do this with each speaker.
I usually do the power wires first, as to NOT make an error and create a small fire!speaker problems, 93 grand caravan -- posted image.
Now.... the deck(s) you purchased... they do work, correct? Test the outputs
Left Front + Dark green
Left Front - BROWN / red
Right Front + Purple
Right Front - Dk.blue/red
Left Rear + BROWN / yellow
Left Rear - BROWN / lt.blue
Right Rear + Dk.blue/white
Right Rear - Dk.blue/orange
tcss
Silver - Posts: 1,623
Posted: October 27, 2007 at 3:51 PM / IP Logged
The front speakers in the Chrysler/Infinity system are amplified. The dark green amp turn on lead needs 12 volts. Also if there is a second ground wire in addition to the braded one it needs to be grounded.
There is no such thing as free installation!
