Posted: October 03, 2014 at 1:38 PM / IP Logged
Posted: October 10, 2014 at 11:11 AM / IP Logged
Posted: December 02, 2014 at 5:37 PM / IP Logged
Posted: March 08, 2015 at 5:00 PM / IP Logged
Posted: March 09, 2015 at 8:44 AM / IP Logged
Posted: March 10, 2015 at 9:08 AM / IP Logged
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
You can do many modern cars this way such as the focus...do the old rx/tx ign wires but do it behind the glove box. Just remember to swap ends on the rx wire if you need to cut it. You are just at the other end of the same wires! Be careful! If the colors don't match that means it passes through another module and you NEED to grab at the recommended places!
Top notch pictorial as usual.
Recently worked on one with a Compustar 7000 + Blade-al. Install went smooth. Accuracy of this pictorial is right on the money !
