2006 tacoma bypass not programing
brianh
Silver - Posts: 516
Posted: January 08, 2008 at 9:17 PM / IP Logged
I have installed a remote start on my truck. It works great, but I am having trouble getting the bypass to program. The bypass I have is the xko5-pkt2 made by Peripheral. I have the chassis ground, 12 volts,imi, imo, and the (- out when running) all hooked up. I am also pretty sure I have the right data wires for the truck because the truck will crank but not start with the wire cut that I have hooked to the bypass. I am sorta stumped by this. If anyone has any info on this I would sure appreciate it.   Thanks in advance.    Brian
Moderator - Posts: 12,488
Posted: January 09, 2008 at 10:34 PM / IP Logged
Everytime you relearn the module you have to reset it. To RESET, press and hold button and plug in module. LED comes on. When LED goes off, release button.
Also, TACOMA V6: Wiring can be found in position 15 and 16 (PIN 15 instead of PIN 26 and PIN 16 instead of PIN 27). This connector is located behind glove compartment at ECM.
chriswallace187
Gold - Posts: 1,661
Posted: January 10, 2008 at 7:29 AM / IP Logged
All that Jeff said, plus you didn't mention the blue ignition input wire from the XK05 being connected?
C Renner's Auto Electronix
brianh
Silver - Posts: 516
Posted: January 10, 2008 at 5:12 PM / IP Logged
Thanks for the replys. I am not getting the red led to light up during pogramming. I do not have the blue ign. wire hooked up. The instructions didnt show it hooking up. That very well could be my problem. I quess it would be a good idea to hook up the green(-) oem security light turn off wire also. Thanks for the info guys. If someone could just let me know about that ign wire I will be set. Thanks a again.     Brian
moonliter
Copper - Posts: 322
Posted: January 10, 2008 at 5:35 PM / IP Logged
The ignition wire is mandatory, it needs to be connected.
brianh
Silver - Posts: 516
Posted: January 10, 2008 at 7:09 PM / IP Logged
Even with the 12 volt constant wire? Not doughting what you are saying, I have just never seen a bypass that had two 12 volt inputs on the unit. Brian
techman93
Silver - Posts: 591
Posted: January 10, 2008 at 8:36 PM / IP Logged
That would be how it senses when key is turned on to program unit on some bypasses. The XK05 is what we use at our shop and I have done a few Toyota's that require to run bypass to behind glove box. You might have the IMI wires reversed. Violet and violet/white may need to be swapped. Test and reset before trying to reprogram.
The security light green wire should be hooked up and the blue wire to ignition as well.
Did the remote starter get tach programmed or is it on voltage sense? Check that and make sure it is set up correctly.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
brianh
Silver - Posts: 516
Posted: January 11, 2008 at 4:28 PM / IP Logged
Thanks for the info. I will hook that blue ign. wire up tommorrow. (I did have to run the wires to the ecm behind the glove box.) I will let you know how it goes. Brian
brianh
Silver - Posts: 516
Posted: January 12, 2008 at 3:41 PM / IP Logged
Thanks for the info guys. Just hooked up the blue ignition wire and it programmed up the first time. The directions given with the bypass do not show hooking that wire up(for the Tacoma) Thanks again.   Brian
extreme1
Silver - Posts: 1,070
Posted: January 12, 2008 at 8:04 PM / IP Logged
you have to hook it up no matter what vehicle it is.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
