2003 acura cl, alarm/remote start wiring
TJ92Civic
Copper - Posts: 161
Posted: January 24, 2008 at 1:16 PM / IP Logged
Can anyone post the wiring for a 2003 Acura CL? Thank you! For a remote start / alarm. Thanks!
bbtaco
Copper - Posts: 119
Posted: January 24, 2008 at 1:58 PM / IP Logged
2003 Acura CL
Battery BROWN AND ORANGE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PINS 12/33 OF 40 PIN PLUG
Ignition 1 YELLOW (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 35 OF 40 PIN PLUG
Ignition 2 LIGHT BLUE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN34 OF 40 PIN PLUG
Accessory 1 GREEN (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 11 OF 40PIN PLUG
Starter 1 BLUE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 15 OF 40 PIN PLUG
Starter 2 LIGHT BLUE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 17 OF 40 PIN PLUG
Key Sense BLUE/WHITE (-) IGNITION SWITCH HARNESS
Neutral Safety GREEN / WHITE (-) AT GEAR SELECTOR SWITCH
Tachometer WHITE (AC) PIN 9 AT THE DATA CONNECTOR
Speed Sense PURPLE (AC) ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG
Parking Lights GREEN (+) AT THE BACK OF PARKING LIGHT UNDER HOOD
Brake Lights RED / BLACK (+) BRAKE PEDAL
Reverse Lights RED (+) ECU PIN13
Horn YELLOW (-) STEERING COLUMN HARNESS
Power Unlock LIGHT GREEN (-) POWER MASTER SWITCH IN DRIVERS DOOR
PowerLock PINK (-) POWER MASTER SWITCH IN DRIVERS DOOR
Driver Mtr Unlock RED (REV) ECU IN DRIVERS DOOR
Driver Mtr Lock GREEN (REV) ECU IN DRIVERS DOOR
Pas Mtr Unlock RED (REV) ECU IN PASSENGER DOOR
LF Window Up RED / YELLOW (REV) DRIVERS DOOR SWITCH
LF Window Dn RED / BLUE (REV) DRIVERS DOOR SWITCH
RF Window Up BLUE / YELLOW (REV) DRIVER KICK PANEL
RF Window Dn BLUE (REV) DRIVER KICK PANEL
TJ92Civic
Copper - Posts: 161
Posted: January 24, 2008 at 3:58 PM / IP Logged
Thanks, that doesn't sound right at all though 2003 acura cl, alarm/remote start wiring -- posted image.
bbtaco
Copper - Posts: 119
Posted: January 24, 2008 at 4:33 PM / IP Logged
I have not done one of these but that's what I have for the 2003, here is one for the 2002 model. Verify the correct wires with a dmm.
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Ignition 2 WHITE/ BLACK (+) IGNITION SWITCH HARNESS
Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
Anti-Theft Type RF ACTIVATED SYS.
Anti-Theft Descript TRANSPONDER
Neutral Safety GREEN / WHITE (-) AT GEAR SELECT SWITCH
Tachometer BLUE (AC) 2 PIN PLUG AT DRIVERS SHOCK TOWER
Speed Sense BLUE/WHITE (AC) CRUISE MODULE - RIGHT OF STEERING COLUMN
Parking Lights RED / BLACK (+) PASSENGER KICK PANEL
Low Crr. Pk Lights RED / YELLOW (-) LEFT OF STEERING COLUMN
Brake Lights WHITE/ BLACK (+) AT BRAKE SWITCH ABOVE PEDAL
Reverse Lights GREEN/ BLACK (+) AT FUSE PANEL - DRIVERS SIDE
Horn LIGHT GREEN/ BLUE (-) IGNITION SWITCH HARNESS
Power Unlock ORANGE (-) 22 PIN CONNECTOR IN FRONT OF THE PASSENGER FUSE BOX
PowerLock BLACK/ BLUE (-) 22 PIN CONNECTOR IN FRONT OF THE PASSENGER FUSE BOX
Here is a post on this model:
Acura CL
TJ92Civic
Copper - Posts: 161
Posted: January 25, 2008 at 1:22 PM / IP Logged
Ok thanks! Ill look at both when I do the install, and test the wires. The second one sounds more likely though.
Thank you!
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
