car wont start with key
1fstls1
Member - Posts: 17
Posted: January 26, 2008 at 9:50 AM / IP Logged
So my remote start worked fine for years then I had a light bulb on the fron corner marker go bad.  Fixed it then my car wont start with the key only with the remte start.  I have been trying to fix this for some time now.  I have tapped into the starter relay under the hood.  The car will turn over then run for 1 second then shut off with the key in the on/run position.  So sounds like a security prob.  I can push the remote start button with the starter wire from the brain unhooked and activate the relay under the hood by hand and the car will start and run.  I have unhooked the remote start and alarm and Paskey transpoder from the car and it still wont start with the key.  I have tried both keys that I have.  I am getting 12v on my yellow starter wire when the key is turned to the start pos but nothing happens.  Any one have any ideas??????  Please help
swerks
Copper - Posts: 224
Posted: January 26, 2008 at 10:58 AM / IP Logged
what kind of car is it?
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
1fstls1
Member - Posts: 17
Posted: January 26, 2008 at 11:01 AM / IP Logged
99 Camaro
1fstls1
Member - Posts: 17
Posted: January 26, 2008 at 11:10 AM / IP Logged
Resistor is in the key and visable.  I think its paskey I
usabuilt
Copper - Posts: 161
Posted: January 26, 2008 at 11:32 AM / IP Logged
If you see a resistor in the key it is a vats system, if it wont start with the key it may be having a problem reading the key, which is a common problem.
Have you tried another key??
1fstls1
Member - Posts: 17
Posted: January 26, 2008 at 11:48 AM / IP Logged
Yes I have two keys tried both.  This is killing me
usabuilt
Copper - Posts: 161
Posted: January 26, 2008 at 11:55 AM / IP Logged
If you know a little about electronics it not very difficult to bypass this system. do you know how to use and ohm meter?
1fstls1
Member - Posts: 17
Posted: January 26, 2008 at 11:57 AM / IP Logged
Yes pleas tell me how more info.  I can hook up a push button switch. anything
usabuilt
Copper - Posts: 161
Posted: January 26, 2008 at 12:02 PM / IP Logged
See it you can get a reading on the resistor pellet in the key is the first step.
1fstls1
Member - Posts: 17
Posted: January 26, 2008 at 12:09 PM / IP Logged
4.71k on one key 4.72k on the ohter.  Now what
Page of 3
Monday, June 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
