chev 2000 pick up starting prob
cool_greg
Copper - Posts: 125
Posted: March 01, 2003 at 7:44 AM / IP Logged
I've installed an autopage 610 in a 2000 chevy pickup, for the life of me i can't figure out what is going on, it cranks but the engine just won't fire, the key works just fine, but if i kind of give the remote start a help buy turning the key just past the ign point but not quite cranking it (so the Acc's turn off) the remote starter will start it. Am I missing something here or what?
floaterr
Silver - Posts: 383
Posted: March 01, 2003 at 8:25 AM / IP Logged
What did you use to bypass the PASSLOCK?
Almost sounds like thats the issue.
If you where to do the same thing you stated above. Letting the truck run for a second then pulling the key out with the truck cont to run.
cool_greg
Copper - Posts: 125
Posted: March 01, 2003 at 9:38 AM / IP Logged
Thanks, any idea on how i go about getting around this?
Your best soultion?
Haku
Copper - Posts: 204
Posted: March 01, 2003 at 9:47 AM / IP Logged
PLDATA Is the easiest way to bypass.
http://sitemanager.theinternetsolution.com/hometronicz/inc/pdetail?v=1&pid=149
Hak
Siemens Autostart
jrilla
Gold - Posts: 1,498
Posted: March 01, 2003 at 10:48 AM / IP Logged
Pldata is the best, but you can accomplish the bypass with a relay and a resistor. Did you know that your car had an anti-theft device? If you are not interested in buying a bypass module, you can email me and I will send you instructions and a relay diagram to bypass the passlock II immobilizer that you truck has.
You will need a DMM
J Rilla
Owner/Installer
Haku
Copper - Posts: 204
Posted: March 01, 2003 at 10:57 AM / IP Logged
I used to love to make these modules myself, but lately... Ive had nothing but problems.  One was a 97 S-10 Blazer, worked fine on remote start.  When you remote start the vehicle the security light turned on and then off like normal, but when you inserted the key, and turned the ignition on, the security light would come on, and stay on.  The vehicle would stay running, and when started with just the key, the light would turn on then off like normal.  In the customers view, somthing was wrong, and they were worried about the car not running, not to mention the bright red security light on.  Pldata fixed this problem, and from an installers view, much easier to install.
Hak
Siemens Autostart
jrilla
Gold - Posts: 1,498
Posted: March 01, 2003 at 11:05 AM / IP Logged
If you get th esecurity light, typically turning the key to start before hitting the break solves that. It helps to have an anti-grind relay in that case if the car does not already have one.
J Rilla
Owner/Installer
floaterr
Silver - Posts: 383
Posted: March 01, 2003 at 11:12 AM / IP Logged
Yeah I had that same issue. Till one day a friends wife said that it never happened with her and we watched her activate the remote start then turn the key to "crank". Even though she was told not to.
Damn dual resistance in IGN switch
cool_greg
Copper - Posts: 125
Posted: March 11, 2003 at 4:30 PM / IP Logged
Thanks everyone for your help, I installed the PLdata rather that doing the build it-yourself, it worked sweet.
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
