auto page rs 622 lcd
pudge211
Member - Posts: 6
Posted: March 29, 2008 at 5:09 PM / IP Logged
I Have installed a RS-622 into a 2005 Silverado using a XPRESSVIP bypass. Install went well. Unit starts vehicle and Locks/unlocks doors. The only problem is that when the key is in ignition and the vehcle is in gear the remote start unit is clicking and sending a " Vehicle running" status to the LCD remote. If you hit the brake it shuts off and then goes thruogh the start up sequence again. What wire don't I have hooked up and where do I hookit up too?? THANK YOU FOR ANY HELP.
brhaugen
Copper - Posts: 275
Posted: March 29, 2008 at 5:17 PM / IP Logged
You may want to double check your wiring, It almost sounds like you have the break pedal shutdown wire with the remote start input wire reversed...
pudge211
Member - Posts: 6
Posted: March 30, 2008 at 12:39 AM / IP Logged
No definitely not thebrakeswitch shut down.  The remote start functions properly until I put it in gear. As soon as i put the vehicle in gear the key fob starts the chirps as if it was to start then chirps to let me know the vehicle is running?? If I hit the brake switch the remote start shuts down and after I let off the brake pedal will go through the same same sequence.
pudge211
Member - Posts: 6
Posted: March 30, 2008 at 1:49 PM / IP Logged
Looking over the install manual I see there is a pink wire for sensor bypass 20 sec. Says some vehicles may require a timed pulsed output or keysense wire. The wiring diagram for 2005 Silverado says N/A. Does this vehicle have a keysense wire and should this pink wire be hooked up to it???
pudge211
Member - Posts: 6
Posted: March 31, 2008 at 7:01 PM / IP Logged
Found the problem. It was in the initial programming. the pulse for the factory alarm was set to .1 (for aftermarket alarm ) and should have been set to 3
