2003 Mitsubishi Montero wiring
Escalade_on20z
Member - Posts: 24
Posted: March 07, 2003 at 9:48 AM / IP Logged
can someone please send me wiring codes for a 2003 Mitsubishi Montero alarm/remote start.
jrilla
Gold - Posts: 1,498
Posted: March 07, 2003 at 10:35 AM / IP Logged
ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+ |ignition harness            |
|          STARTER|blk/yel or blk/blu |+ |ignition harness            |
|        IGNITION|BLACK/ white        |+ |ignition harness            |
|        ACCESSORY|blue/red            |+ |ignition harness            |
| SECOND ACCESSORY|blue               |+ |ignition harness            |
|       POWER LOCK|BLACK/ red *1        |- |right rear side of fuse box |
|     POWER UNLOCK|BLACK/ blue *1       |- |right rear side of fuse box |
| PARKING LIGHTS +|GREEN / WHITE        |   |headlight switch            |
|       HEADLIGHTS|red                 |- |headlight switch            |
|     DOOR TRIGGER|GREEN/ red           |- |top of fuse box *2          |
| TRUNK/HATCH PIN|tied in with door   |   |                            |
|        HOOD PIN|                    |   |                            |
| FCTRY ALARM ARM|blue / YELLOW        |- |drivers kick panel          |
|FCTRY ALRM DISARM|BLACK/ red           |- |drivers kick panel          |
|       TACHOMETER|wht/blk or white    |   |coil or ignition module *3 |
|      SPEED SENSE|yellow/white        |   |data link connector *4      |
|       BRAKE WIRE|green               |+ |brake switch               |
|     HORN TRIGGER|green               |+ |horn or relay underhood     |
|           WIPERS|blu/red(L),blu/blk(H|+ |steering column             |
| LF WINDOW UP/DN|red - green        |A |drivers door switch        |
| RF WINDOW UP/DN|RED / blu - blk/yel   |A |drivers switch or kick panel|
| LR WINDOW UP/DN|RED / wht - grn/wht   |A |drivers switch or kick panel|
| RR WINDOW UP/DN|RED / wht - grn/wht   |A |drivers switch or kick panel|
| SUN RF OPN/CLOSE|blu/wht - blue      |A |motor at front of sunroof   |
| RADIO ILLUMINATE|GREEN/ blue          |+ |radio                      |
|    POWER ANTENNA|WHITE/ black        |+ |radio                      |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555U to bypass. *1 Warning! When doing door locks on these trucks make sure you DO NOT cycle the door locks rapidly. This may cause the ETACS module to fail and the door locks will no longer work. Also, you MUST add diodes to the lock and unlock output from our units to prevent damage to the ETACS. Make sure you insert the diodes with the cathode (stripe side) towards our unit. *2 In a 2 pin plug. Also found in the drivers A pillar. *3 On the 2.4L, tach is wht/blk at the coil on the left front of the engine compartment. On the 3.0L and 3.5L it is white at the ignition module next to the coils on the right rear side of the engine compartment under the plastic motor cover. *4 The data link connector is under the driver side dash, near the relay box.
J Rilla
Owner/Installer
