2009 kia borrego
brianh
Silver - Posts: 516
Posted: June 07, 2009 at 8:44 PM / IP Logged
I am in the process of installing a remote start on this vehicle. I do not have any info on the factory alarm disarm wire(color, location, polarity) I am using the express kit DLPK unit to do door locks, door triggers and trunk release. Some vehicles show this unit doing factory alarm disarm. Not for the Borrego though. Also. anyone have any advice on running the antenna wire past the a pillar air bag. Any tips or advice would be great! Thanks in advance! Brian
tommy...
Gold - Posts: 1,901
Posted: June 07, 2009 at 9:10 PM / IP Logged
BatteryWHITE(+)IGNITION SWITCH HARNESS2009 kia borrego -- posted image.
2009 kia borrego -- posted image.Ignition 1GREEN(+)IGNITION SWITCH HARNESS
2009 kia borrego -- posted image.Starter 1ORANGE(+)IGNITION SWITCH HARNESS
2009 kia borrego -- posted image.All Door Trigger2009 kia borrego -- posted image.
2009 kia borrego -- posted image.LF LatchYELLOW(-)AT RAM MODULE ON LEFT SIDE OF TRUNK
2009 kia borrego -- posted image.RF LatchBLUE/ORANGE(-)AT RAM MODULE ON LEFT SIDE OF TRUNK
2009 kia borrego -- posted image.LR LatchPINK(-)AT RAM MODULE ON LEFT SIDE OF TRUNK
2009 kia borrego -- posted image.RR LatchORANGE(-)AT RAM MODULE ON LEFT SIDE OF TRUNK
2009 kia borrego -- posted image.Trunk TriggerWHITE(-)AT RAM MODULE ON LEFT SIDE OF TRUNK
2009 kia borrego -- posted image.Hood TriggerORANGE(-)VEHICLE HOOD PIN SIWTCH2009 kia borrego -- posted image.
2009 kia borrego -- posted image.Alarm DisarmRED(-)DRIVER DOOR MODULE IN DRIVER DOOR...#12009 kia borrego -- posted image.
2009 kia borrego -- posted image.Alarm ArmORANGE(-)DRIVER DOOR MODULE IN DRIVER DOOR...#22009 kia borrego -- posted image.
2009 kia borrego -- posted image.Parking LightsBLUE(-)VEHICLE LIGHT SWITCH
...#1...TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER, THIS WIRE WILL ALSO UNLOCK ALL DOORS WITH A DOUBLE PULSE
...#2...TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER, THIS WIRE WILL ALSO LOCK THE DOORS
What kind of Remote Start...?
M.E.C.P & First-Class
brianh
Silver - Posts: 516
Posted: June 07, 2009 at 9:59 PM / IP Logged
I am installing a Viper 5901 R.S on this vehicle. I just cant find any info on this vehicle because its so new. Do you have all the wiring info avalible? If so could you post it as well? Thanks for your help on this. Any tips of hints with this unit are very welcome. Thanks again. Brian
tommy...
Gold - Posts: 1,901
Posted: June 08, 2009 at 2:27 PM / IP Logged
I dont know if the post is too big...But it wont let me post the wire desription
tommy...
Gold - Posts: 1,901
Posted: June 08, 2009 at 2:31 PM / IP Logged
Audio/Mobile Video
WIRECOLORPOLARITYLOCATION
BatteryRED(+)RADIO HARNESS
AccesoryRED / ORANGE(+)RADIO HARNESS
GroundBLACK(-)RADIO HARNESS
IlluminationRED(+)RADIO HARNESS
DimmerBROWN(-)RADIO HARNESS
Power AntennaRED(+)RADIO HARNESS
Amp Turn OnBLACK/ ORANGE(+)RADIO HARNESS
Amp LocationLEFT SIDE OF CARGO AREA UNDER CARPET
Steering CntrlsYES
Speed CntrlYES
Radio SecurityYES
tommy...
Gold - Posts: 1,901
Posted: June 08, 2009 at 2:32 PM / IP Logged
Convenience
Headlights-LoGREEN/ ORANGE(-)VEHICLE LIGHT SWITCH
All Hazrd LightsPINK(-)VEHICLE HAZARD SWITCH
Wipers-LoBLUE(+)WIPER CONTROL SWITCH
Wipers-HiBROWN(+)WIPER CONTROL SWITCH
Parking BrakeYELLOW(-)PARKING BRAKE SWITCH
Fuel Dr ReleaseYELLOW(-)AT DRIVER DOOR MODULE IN DRIVER DOOR
tommy...
Gold - Posts: 1,901
Posted: June 08, 2009 at 2:33 PM / IP Logged
Remote Start
THIS WIRE IS FUSED AT 30 AMPS, ALSO YELLOW AT IGNITION SWITCH HARNESS FUSED AT 25 AMPS
Ignition 2BLUE(+)IGNITION SWITCH HARNESS
Accessory 1PINK(+)IGNITION SWITCH HARNESS
Anti-Theft TypeUNIVERSAL IMMOBILIZER
Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
TachometerBLACK(AC)AT ECM MODULE NEAR DRIVER FIREWALL UNDER HOOD
Speed SenseWHITE/ BLACK(AC)AT DATA LINK CONNECTOR
Brake LightsWHITE(+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightsRED / BLACK OR RED(+)AT RAM MODULE ON LEFT SIDE OF CARGO AREA BEHIND TRIM PANEL
HornGRAY(-)IN HARNESS AT STEERING COLUMN
Rear DefrostRED / ORANGE
THIS WIRE WILL ALSO CONTROL HEATED MIRRORS IF EQUIPPED
tommy...
Gold - Posts: 1,901
Posted: June 08, 2009 at 2:36 PM / IP Logged
Modules
WIRELOCATION
Module 1RAM MODULE - BEHIND TRIM ON LEFT SIDE OF CARGO AREA
Module 2ECM MODULE - UNDER HOOD BETWEEN FIREWALL AND AIR CLEANER ASSEMBLY
Module 3FAM MODULE - UNDER DRIVER SIDE OF DASH TO LEFT OF STEERING COLUMN
Doorlocks/Windows
Power UnlockRED(-)DRIVER DOOR MODULE IN DRIVER DOOR
TEST THIS WIRE WILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER. WILL ALSO DISARM THE FACTORY ALARM IF EQUIPPED
PowerLockORANGE(-)DRIVER DOOR MODULE IN DRIVER DOOR
TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER, WILL ALSO ARM THE FACTORY ALARM IF EQUIPPED
Sunroof OpenBLUE(-)SUNROOF CONTROL SWITCH
Sunroof CloseGREEN(-)SUNROOF CONTROL SWITCH
brianh
Silver - Posts: 516
Posted: June 09, 2009 at 5:41 PM / IP Logged
Thanks for all of the quick info! I have got the remote starter/alarm all hooked up. No problem. I was on the phone several times today with Trilogics about thier expresskit bypass. This thing is more trouble than its worth. First they had no clue as to what colors the can wires I should look for were .( Its not even posted on thier web site) They finally told me high was red and low was blue. Thats what it looks like in the car.   I have another question also. In the directions( on expresskit.com) for the 2009 Kis Borrego, it says to hook the main power harness (blue) wire up to 12 volts and the black wire to ground. To cut out the red and green wires. I have done this for a long time now and I have never hooked 12 volts to the tx or rx wire. Is this something new?   I cant program the data bypass because the led wont come on on the unit. Until I get it straightened out I cant program the remote start unit either.(unit has to see door open to go into program mode)   Any help at all with this is much appreciated.   Thanks in advance. Brian
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
