2004 lincoln town car alarm/remote start
purevision
Member - Posts: 10
Posted: January 05, 2010 at 10:55 PM / IP Logged
Hi does anyone, have the wiring info for a 2004 lincoln town car.  Thanks
zerepdivad
Silver - Posts: 605
Posted: January 06, 2010 at 2:13 AM / IP Logged
     Battery          LIGHT GREEN/ VIOLET @ YELLOW          (+)          IGNITION SWITCH HARNESS
     Ignition 1          WHITE/ YELLOW          (+)          IGNITION SWITCH HARNESS
     Ignition 2          GRAY / YELLOW          (+)          IGNITION SWITCH HARNESS
     Accessory 1          PINK/BLACK          (+)          IGNITION SWITCH HARNESS
     Accessory 2          PINK/BLACK          (+)          IGNITION SWITCH HARNESS
     Starter 1          RED / BLUE          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          SECURILOCK
     Anti-Theft Descript          AN RF SIGNAL ACTIVATED SYSTEM
     Key Sense          BLACK/ PINK          (-)          IGNITION SWITCH HARNESS
     Tachometer          LIGHT GREEN/ ORANGE          (AC)          DRIVERS SIDE FUEL INJECTOR
     Speed Sense          DARK BLUE / YELLOW          (AC)          104 PIN CONN. PIN 84 ON THE DRIVERS SIDE FENDERWELL
     Parking Lights          WHITE/ BLACK          (-)          AT VEHICLE LIGHT SWITCH
     Brake Lights          LIGHT GREEN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          BLACK/ PINK          (+)          IN HARNESS IN DRIVERS KICKPANEL
     Horn          BLUE          (-)          PLUG TO RT. OF STEERING COLUMN
     Power Unlock          PINK/GREEN          (+)          AT DDM IN DRIVERS DOOR
     PowerLock          PINK / YELLOW          (+)          AT DDM IN DRIVERS DOOR
     All Door Trigger          BLACK/ BLUE          (+)          AT UNDERDASH LIGHT
     Domelight Super          BLACK/ BLUE          (+)          AT UNDERDASH LIGHT
     LF Latch          DARK BLUE          (-)          IN DRIVERS DOOR
     RF Latch          BLACK/ ORANGE          (-)          IN DRIVERS DOOR
     LR Latch          BLACK/ ORANGE          (-)          IN DRIVERS DOOR
     RR Latch          BLACK/ ORANGE          (-)          IN DRIVERS DOOR
     Trunk Trigger          BROWN / WHITE          (-)          DRIVERS SILL PLATE HARNESS
     Alarm Disarm          BLUE/BLACK          (-)          IN DRIVERS DOOR
A DMM is a beautiful thing.
chev104275
Gold - Posts: 1,433
Posted: January 06, 2010 at 4:56 AM / IP Logged
the only wire i wouldnt use is the WHITE/ black parking light wire if the car has auto lights the parking lights wont come on when the switch is in auto
use the brown (positive trigger) at the lighting control module that way the parking lights will always come on no matter where the switch is
purevision
Member - Posts: 10
Posted: January 06, 2010 at 2:53 PM / IP Logged
Thanks for the response, this will work!
