2004 infinity fx45
partyguy
Member - Posts: 30
Posted: February 06, 2010 at 6:53 PM / IP Logged
hello all i have a request do a remote start on a 2004 infinity fx45 does anyone have any wiring info on this vehicle???
monty_77
Copper - Posts: 491
Posted: February 07, 2010 at 12:48 AM / IP Logged
Infiniti FX45 2004
WIRE        COLOR           LOCATION        POL.
Battery 1 Blue/Red Or Red Ignition Harness Positive
Ignition 1 Black Ignition Harness Positive
Starter 1 Blue Ignition Harness Positive
Starter 2 Pink Ignition Harness Positive
Accessory 1 White Ignition Harness Positive
Parklights Positive White White 16 pin Conn. above Driver's Kick Panel Positive
Brake Lights Pink At Brake Switch or Driver's Kick Panel Positive
Horn GREEN/ Black Large White Conn. At Right Of Sterring Collumn Negative
Tach White PCM Under Glove Compartment Pin 14
Lock Empty Spot At BCM At BCM White 15 Pins Position A5 (1) Negative
Unlock Orange At BCM White 40 Pins Position A14 (1) Negative
Trunk With Unlock
Driver Door Unlock Yellow At BCM Black Plug pin 44 Reverse
E-Brake Blue Parking Brake Switch Negative
OEM Hood Switch Lt Green In Engine Compartment At hood Switch Negative
Disarm Same as Unlock Same as Unlock Negative
Rearming Same as Lock Same as Lock Negative
Dome Sensor PURPLE / White At BCM Black 15 Pins Conn. Pin A8 Negative
Trunk Pin Blue At BCM White 15 Pins Conn. Pin A3 Negative
KeySense BLACK/ White At BCM White 40 Pins Conn. Pin 24 Positive
Door Pin FL White At BCM White 15 Pins Conn. Pin A7 Negative
Door Pin RL Pink At BCM White 15 Pins Conn. Pin A8 Negative
Door Pin FR Pink/Black At BCM White 40 Pins Conn. Pin 9 Negative
Door Pin RR Pink/Blue At BCM White 40 Pins Conn. Pin 8 Negative
Rear Defogger Blue/White (2) At BCM White 40 Pins Conn. Pin 12 Negative
Auto lights OFF Green At BCM White 40 Pins Conn. Pin 28 Negative
Moon Roof Tilt Brown At Moon Roof Switch Neg .7
Moon Roof Open Lt.Green At Moon Roof Switch Neg .7
Moon Roof Close Brown At Moon Roof Switch Neg .7
Memory Seat 1 Pink At Driver's Seat Switch Negative
Memory Seat 2 Green At Driver's Seat Switch Negative
BackUp Lights Green Top conn In Driver's Kick 16 Pins Plug Negative
Comments :
Note :This vehicle is equiped with a immobilizer system that needs to be bypassed,( Transponder )
This car come with 3 keys from factory. Use the Key with the Black Infiniti Logo on it,
(1) To Arm, Disarm, Lock and Unlock, you can connect the wire inside the door, or inside the BCM solder to the PC-Board under the 15 pins and
40 pins connectors. There is 2 empty spot, one in the 15 pins plug and one in the 40 pins plug. The BCM is located in the Driver's Kick Panel,
to connect the door lock, you need to open the Box and solder a wire to the PC-Board where pin A5 of the 15 pins connector was located.
For the Unlock, solder a wire to Pin 14 of the 40 pins connector The Unlock require 2 pulse, the first one will only disarm
(2) 1 Pulse to turn it ON and one to turn it OFF. It's also gonna turn the Rear Defrost Light indicator ON.
if you do not feel comfortable soldering in the BCM buy a doorlock bypass or buy a combo unit that does the Immobilizer and the dootlocks
partyguy
Member - Posts: 30
Posted: February 07, 2010 at 10:29 AM / IP Logged
thanks you that helps me out alot
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
