autopage c3-rs-665, c3-rs-730
dustintucker2
Member - Posts: 13
Posted: May 21, 2010 at 11:59 PM / IP Logged
In the process of installing in my car but i need the install manual... any help would be greatly appreciated.
Dtuck
topperz7
Member - Posts: 14
Posted: May 22, 2010 at 5:34 PM / IP Logged
I install Autopage alarms. I always give the install and owners manual to the customer. I could probably answer any question you have as far as what each wire color does
dustintucker2
Member - Posts: 13
Posted: May 22, 2010 at 5:51 PM / IP Logged
Well I'm still waiting on it to come in the mail and I'm assuming it does not come with install manual as most of them do not. When i get it i may give you a call for help thanks!
Dtuck
mikvot
Gold - Posts: 1,043
Posted: May 22, 2010 at 10:43 PM / IP Logged
If the unit does not come with an install manual, then you are not buying it from a reputable place or are buying a refurbished unit. I have not seen an Autopage unit come without an install manual. This is the same for most companies, although some will provide only a shortcut manual, which prevents people, that shouldn't be installing, from doing just that.
dustintucker2
Member - Posts: 13
Posted: May 23, 2010 at 11:15 PM / IP Logged
Oh ok... i saw somewhere online where it said they did not come with one.. and it's a new system and i have not gotten it yet so i'm not sure i'm just trying to cover my behind.. and i have done quite a bit of electronic installations in cars and if i think i'm in over my head i'll take it to a pro... thanks for all the help
Dtuck
dustintucker2
Member - Posts: 13
Posted: May 24, 2010 at 12:08 AM / IP Logged
also... if i have factory door latch sensors already is there a way to tie those in to the sensor on the brain of the alarm?
Dtuck
dustintucker2
Member - Posts: 13
Posted: May 24, 2010 at 12:11 AM / IP Logged
also that includes the trunk and the hood
Dtuck
dustintucker2
Member - Posts: 13
Posted: May 24, 2010 at 2:38 PM / IP Logged
Update... Have decided to order the AUTOPAGEŽ C3-RS-730 instead. It is on it's way and should be here by friday or monday. Above question still remain un answered.
Dtuck
dustintucker2
Member - Posts: 13
Posted: May 24, 2010 at 8:30 PM / IP Logged
Anyone got the install manual for the autopage c3-rs-730
Dtuck
dustintucker2
Member - Posts: 13
Posted: May 24, 2010 at 10:27 PM / IP Logged
also is there any way to wire the led warning light into windshield wiper lights?.. like the fluid shooters?
Dtuck
