2010 toyota tacoma
maxcat
Copper - Posts: 211
Posted: October 30, 2010 at 2:48 PM / IP Logged
Hey Guys, can anyone tell me if the wiring for the 2010 Tacoma is the same as the 2009 wiring.
Thank you in advance
Platinum - Posts: 7,828
Posted: October 30, 2010 at 2:55 PM / IP Logged
Here is a link to Bulldog Security :  http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp  According to them the 2009 and 2010 are the same.
Mike M2
Platinum - Posts: 2,652
Posted: October 30, 2010 at 6:29 PM / IP Logged
The same since 2007 other than new 80bit immobilizer...
Mike M2
Tech Manager
CS Dealer Services
bamafan76
Member - Posts: 6
Posted: October 31, 2010 at 4:34 PM / IP Logged
Funny that you ask this, I started wiring my 2010 Tacoma with an alarm today using the Bulldog wiring diagram and found out it isn't completely accurate in that it isn't just one door switch wire (GREEN/ YELLOW as it states). It is in fact running off of 3 different wires for the door switches; YELLOW /GREEN for drivers front, RED / black for pass. front and pink/black for rear doors (for double cab). My problem is I found the driver's front wire and passenger rear doors wire but can't find the passenger's front door wire. I also can't find the door lock/unlock wires. Can anyone help with finding these wires?
According to the wiring diagram they are in the following location but could use some help/pictures finding exactly where these OEM pin connectors are:
RED / Black-Dash Fuse Box, white 22 pin connector (front or back of fuse box?)
Lock-Blue/White, Driver's Kick panel, white 10 pin connector (exact location/pics?)
Unlock- Gray, Driver's Kick panel, white 10 pin connector (exact location/pics?)
Factory Alarm Arm- Violet, Driver's kick panel, white connector (exact location/pics?) Not sure if these apply as I only have OEM keyless entry, not OEM alarm
Factory Alarm Disarm- GREEN/ Black, Driver's kick panel, white 10 pin connector (exact location/pics?) Not sure if these apply as I only have OEM keyless entry, not OEM alarm
Also I have read something about a child safety door lock circuit. Does anyone know if this is the case with my 2010 Tacoma Double Cab and if so how to wire?
Thanks a million to any help provided!
Posted: October 31, 2010 at 4:42 PM / IP Logged
Here is the wire listing from AudioVox :
Audio/Mobile Video
 WIRE  COLOR  POLARITY  LOCATION
 Battery  LIGHT BLUE  (+)  RADIO HARNESS
 Accesory  GRAY  (+)  RADIO HARNESS
 Ground  BROWN  (-)  RADIO HARNESS
 Illumination  GREEN  (+)  RADIO HARNESS
 Amp Location  BEHIND THE PASSENGER REAR SEAT
 Steering Cntrls  YES
 Speed Cntrl  NO
 Radio Security  YES
Security
 Battery  WHITE/ BLUE & WHITE/ RED  (+)  IGNITION SWITCH HARNESS
 Ignition 1  BLUE / YELLOW  (+)  IGNITION SWITCH HARNESS
 Starter 1  BLACK/ WHITE  (+)  IGNITION SWITCH HARNESS
 All Door Trigger  GREEN / WHITE  (-)  MAIN BODY ECU
 Domelight Super  BLUE  (-)  UNDER DASH FUSEBOX
 LF Latch  GREEN/ YELLOW  (-)  UNDER DASH FUSEBOX
 RF Latch  RED / BLACK  (-)  UNDER DASH FUSEBOX
 LR Latch  PINK/BLACK  (-)  UNDER DASH FUSEBOX
   EITHER WIRE WILL MONITOR BOTH REAR DOORS
 RR Latch  PINK/BLACK  (-)  UNDER DASH FUSEBOX
 Alarm Disarm  GREEN/ BLACK & WHITE/ RED  (-)  MAIN BODY ECU
   TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER, USE DOUBLE PULSE TO UNLOCK ALL DOORS, CAN ALSO USE KEYSENSE WIRE FOR DISARM NO UNLOCK
 Alarm Arm  VIOLET  (-)  VEHICLE FUSEBOX
 Parking Lights  GREEN  (+)  UNDER DASH FUSEBOX
 Low Crr Pk Lights  GREEN  (-)  AT VEHICLE HEADLIGHT SWITCH
   ALSO AT MAIN BODY ECU PIN 13
Convenience
 Headlights-Lo  PINK  (-)  AT VEHICLE LIGHT SWITCH
 Headlights-Hi  RED / GREEN  (-)  AT VEHICLE LIGHT SWITCH
 LF Pk Lt Bulb  GREEN  (+)  AT FRONT LEFT PARKING LAMP
 RF Pk Lt Bulb  GREEN  (+)  AT FRONT RIGHT PARKING LAMP
 LR Pk Lt Bulb  GREEN  (+)  AT REAR LEFT TAIL LIGHT ASSEMBLY
 RR Pk Lt Bulb  GREEN  (+)  AT REAR RIGHT TAIL LIGHT ASSEMBLY
 All Hazrd Lights  RED / WHITE  (-)  AT HAZARD SWITCH
   ALSO AT UNDER DASH FUSEBOX
 LF Hazrd Bulb  YELLOW  (+)  AT FRONT LEFT TURN SIGNAL LIGHT
 RF Hazrd Bulb  LIGHT BLUE  (+)  AT FRONT RIGHT TURN SIGNAL LIGHT
 LR Hazrd Bulb  YELLOW  (+)  AT REAR LEFT TAIL LIGHT ASSEMBLY
 RR Hazrd Bulb  BLUE/WHITE  (+)  AT REAR LEFT TAIL LIGHT ASSEMBLY
 Wipers-Lo  BLUE/BLACK  (+)  AT WIPER CONTROL SWITCH
 Wipers-Hi  BLUE/RED  (+)  AT WIPER CONTROL SWITCH
 Parking Brake  GREEN/ YELLOW  (-)  UNDER DASH FUSEBOX
Remote Start
 Ignition 2  BLACK/ RED  (+)  IGNITION SWITCH HARNESS
 Accessory 1  WHITE/ GREEN  (+)  IGNITION SWITCH HARNESS
 Starter 2  GREEN/ BLACK  (+)  IGNITION SWITCH HARNESS
 Anti-Theft Type  UNIVERSAL IMMOBILIZER
 Anti-Theft Descript  THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
 Key Sense  GREEN/ BLACK  (-)  IGNITION SWITCH HARNESS
   THIS WIRE WILL ALSO DISARM THE FACTORY ALARM WITHOUT UNLOCKING THE DOORS
 Tachometer  BLACK/ WHITE  (-)  OBDII CONNECTOR
 Speed Sense  VIOLET/WHITE  (AC)  RADIO HARNESS
 Low Crr. Pk Lights  GREEN  (-)  AT VEHICLE HEADLIGHT SWITCH
 Brake Lights  BLUE  (+)  AT SWITCH ABOVE BRAKE PEDAL
 Reverse Lights  RED  (+)  IN HARNESS IN DRIVER KICKPANEL
 Horn  GREEN/ RED  (-)  UNDER DASH FUSEBOX
 IMO  LIGHT GREEN/ BLACK  (DATA)  AT TRANSPONDER ECU BEHIND CLUSTER
 IMI  BLUE/WHITE  (DATA)  AT TRANSPONDER ECU BEHIND CLUSTER
Modules
 WIRE  LOCATION
 Module 1  MAIN BODY ECU - PART OF UNDER DASH FUSEBOX
 Module 2  ECM - BEHIND GLOVEBOX TO RIGHT
 Module 3  ABS MODULE - UNDER HOOD NEAR DRIVER FIREWALL OR PASSENGER FENDER DEPENDING ON EQUIPMENT
bamafan76
Member - Posts: 6
Posted: October 31, 2010 at 6:51 PM / IP Logged
Security
After reading the above, does the "All door trigger GREEN / WHITE" take the place of having to wire the other three associated with the latches? If so that would be the route I take! Thanks!
Posted: October 31, 2010 at 6:58 PM / IP Logged
Yep, save some diodes....
Mike M2
Posted: October 31, 2010 at 9:17 PM / IP Logged
The GREEN / WHITE all door trigger is actually the wire for the door open indicator on your instrument cluster, so yes it will cover all 4 doors with no delay. Remove the 2 10mm nuts and the bracket in the lower left side of the BCM, pull it down and look at the back. It will be in the closest plug to you kinda in the middle...
Also, do not use the lock/unlock listed above. The purple arm and GREEN/ black disarm wires will operate the locks for you even without you having an OEM alarm. You will find them in the plugs in the kickpanel that come from the drivers door boot. They are loose plugs and the wires are covered with black plastic. The disarm wire will unlock the drivers door with the first pulse and the 3 others with a second pulse....
Mike M2
Tech Manager
CS Dealer Services
bamafan76
Member - Posts: 6
Posted: October 31, 2010 at 9:20 PM / IP Logged
Thanks so much to all, I knew I'd find what I needed here!
When you say loose plugs, are you meaning they won't actually be plugged into anything?
Mike M2
Posted: November 01, 2010 at 6:18 AM / IP Logged
By loose i mean they aren't mounted to the chassis of the truck like all the other plugs.
Mike M2
Tech Manager
CS Dealer Services
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
