Ford FreeStyle 2006
WIRE COLOR LOCATION POL.
Battery 1 Red (30 amp) At Steering Column Positive
Ignition 1 Lt GREEN/ Purple At Steering Column Positive
Starter 1 Dk Green At Steering Column Positive
Accessory 1 Gray / YELLOW At Steering Column Positive
Parklights - BLACK/ Green See Diagram (1) At Light Switch Negative
Brake Lights RED / Green (8) At Brake Switch Above Brake Pedal Positive
Horn Dk.Blue At Steering Column (4) Negative
Tach Lt.GREEN / WHITE On Top Of Engine 1 Cyl
Lock Pink / YELLOW At Driver's Kick Panel (5) Negative
Unlock Pink/Green At Driver's Kick Panel (5) Negative
Driver Door Unlock Yellow At Driver's Kick Panel Reverse
E-Brake RED / Yellow At Parking Brake Switch Negative
OEM Hood pin PURPLE / Orange (2) At Top Of Smart Junction Box Open
Disarm Lt.Blue/Black (3) At Driver's Kick panel (5) Negative
Rearming Red + Yellow/Black (6) At Driver's Kick Panel (5) Negative
Trunk Pin WHITE/ Purple At Driver's Kick Panel (5) Open
KeySense Yellow At Steering Column Positive
Door Pin FL Lt GREEN/ Black At Driver's Kick Panel (5) Open
Door Pin RL PURPLE / Lt Green At Smart Juction Box Blue Conn. Open
Door Pin FR Yellow/ Lt Green At Smart Juction Box Blue Conn. Open
Door Pin RR Red At Smart Juction Box Blue Conn. Open
Fuel Pump Pink/Black or White At Inertia Fuel Shutoff switch in Pass. Kick Positive
Rear Defogger Pink Behind Defogger Switch Assembly (7) Negative
Head Lights RED / White (9) At Light Switch Negative
Moon Roof Tilt Black At Moon Roof Switch 1 Sec (-)
Moon Roof Open White At Moon Roof Switch 15 Sec (-)
Moon Roof Close Brown At Moon Roof Switch 15 Sec (-)
Memory Seat 1 BROWN / Green At Driver's Kick Panel Negative
Memory Seat 2 BLACK/ Orange At Driver's Kick Panel Negative
BackUp Lights WHITE/ Yellow At Driver's Kick Panel Positive
Driver Heated Seat WHITE/ Red Behind Climate Control Module Blue conn. Negative
Passenger Heated SeatWHITE/ Yellow Behind Climate Control Module Blue conn. Negative
Transponder RX Gray/Orange At Transopnder Module Data
Transponder TX WHITE/ Lt.Green At Transopnder Module Data
Transponder IgnitionRED / Yellow At Transopnder Module Positive
This car is equiped with a Transponder immobilizer system that need to be bypass.
(1) Wires at the lightwitch are multiplexed. You must install a relay to activate the Parklights when you have AutoLight feature. See
diagram. If you don't have that feature, use the BLACK/ Green (-) behind the light switch.
(2) Need to change the programmation of the remote starter for (Normally Open Switch).
(3) Don't need to disarm before the runtime. For Unlock you need to pusle this wire and the Unlock simultaniously with 2 diodes.
(4) Can also be found at the Smart Junction Box, in the Black connector (Top Left)
(5) Can also be found at the Smart Junction Box, in the Blue connector (Lower Left)
(6) Pulse both with (-) at the same time. The Red wire will give ground with the button 9/0 of the driver's door keypad. The Yellow/Black
will give ground with the 7/8 button press.
(7) Can also be found at the Smart Junction Box in the Black 32 pin Connector, See picture.
(8) Brakes work with Ignition ON only.
(9) See Diagram on how to turn ON the HeadLights.
This data sheet is supplied as information purpose only. Directed does not, in any way, warranty accuracy of the data. Before attempting any installation or connections, the installer should verify all wires with either a multi-Meter or a high level probe that is computer and air bag safe. At all time, the installer assumes all damages, defects, or all other problems that could be linked to the installation process. Directed, 2009. All rights reserved.
If you want detail pics send me an email or pm with the year make and model in subject line
