2011 mazda tribute park wire
bruc007
Copper - Posts: 74
Posted: October 14, 2011 at 10:05 PM / IP Logged
Hi, just finished a 2011 Tribute and although there are PURPLE / white wires running in the dkp none will activate the parks.Just wondering if anyone has done one of these and has a location and color wire without going to the fuse panel side of the console.It is a lot of work to go thru to access one wire. Anything at the switch .neg or pos?
thanks Bruce
Platinum - Posts: 7,828
Posted: October 15, 2011 at 2:13 AM / IP Logged
If the Tribute is like it's Ford counterparts, I'd stay away from the (-) Parking Light wire.   Here is a note from DEI  :
May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ blue at the headlight switch, gray 10 pin plug, pin 7. See Tech Doc 1096 for wiring information.
The (+) Parking Light wire at the SJB is the safe way to go if you can't locate the PURPLE / White wire in the DKP.
dasbogie
Silver - Posts: 514
Posted: October 15, 2011 at 6:50 AM / IP Logged
If you pry the shifter trim off the center console and then pry up the top of the entire center console, that's all you need to remove.  The PURPLE / white wire is in a plug near the shifter, it will test as +.
Advanced
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
