2007 nissan murano parking light location
sucks37123
Member - Posts: 20
Posted: December 02, 2012 at 9:35 PM / IP Logged
I need to know the easiest way to tap in to the parking lights for a 2007 nissan murano s?
Platinum - Posts: 7,802
Posted: December 03, 2012 at 5:26 AM / IP Logged
Here is a link to the Ready Remote wiring info for your vehicle :
http://www.readyremote.com/main.asp?make=Nissan&model=Murano
Parking Lights+   RED / Blue (+)      above driver kick, gray 16 pin plug, pin 14
This same wire can be found lower in the drivers kick panel in the harness run
that goes toward the rear of the vehicle.  There will be several RED / Blue wires
in this harness, so, as always, use a Digital Multi Meter to test for and verify the
correct wire.  Ensure that you set your R/S unit to (+) Parking Light output and
solder your connection.
Mike M2
Platinum - Posts: 2,652
Posted: December 03, 2012 at 5:43 PM / IP Logged
It's much easier to get it at the switch that is located under the drivers side AC vent(i forget what it is, maybe driving lights?) Anyway, there is a switch mounted on the dash there and there is a RED / blue positive park light wire on the plug for it. It stops me from having to remove the kick panel....
Mike M2
Tech Manager
CS Dealer Services
