2003 camry no start
yyqq
Member - Posts: 6
Posted: December 15, 2014 at 8:22 PM / IP Logged
I just installed a 2003 Camry. auto 4 cyl. with cs800-s and ads-tb. there is no factory alarm. I can lock and unlock. but no start.no parking light flashing. even I put key into the keyport and by keyport. bypass light are normal and flashing green during remote start. I tested starter main power wiring with every key position. connections were right. I tried tach and tachless. still not working. I connected key sense with diode.
there are 2 install types. I used tpye one. all wires matched the diagram type one. but I found later all wire positions and wire colors are same in both types.which one I should use.
the pin 7 is ground in the reference chart. but there is no this wire in the wiring diagram. should I connect it?
Any help would be greatly appreciated!
tedmond
Gold - Posts: 4,610
Posted: December 15, 2014 at 9:02 PM / IP Logged
Vehicle has 2 starter and 2 ignition wires. By default the compustar is set for tach mode and you must program tach before it will start. Any remote start error number ? You can count with the parking light
Ted
Compustar Expert
yyqq
Member - Posts: 6
Posted: December 15, 2014 at 9:56 PM / IP Logged
thanks a lot. tedmond. I did not connect start#2. thanks for reminding me.
