deleting a remote from compustar cm7200
spincycle
Member - Posts: 14
Posted: January 09, 2015 at 8:10 PM / IP Logged
Hi,
I was programming a 2way remote for a compustar CM7200 in second car mode on the remote. The problem is I didn't have it in 2nd car, so the remote now operates both cars at once.
How can I remove the remote from the CM7200? I have tried reprogramming it again, but it still operates both cars on a key press.
Thanks for the help!
tedmond
Gold - Posts: 4,610
Posted: January 09, 2015 at 10:14 PM / IP Logged
you need to erase all remote. Program all remotes again and make sure you fill up all 3 spaces.
Enter remote programming, press lock on remote 1, lock on remote 2, lock again on remote 3 (or 2nd car function)
Ted
Compustar Expert
spincycle
Member - Posts: 14
Posted: January 10, 2015 at 9:39 AM / IP Logged
How do I erase all remotes?
I programmed all three remotes again (the one in second car mode) and it still out of second car mode operates both cars simultaneously. It's frustrating... lol
tedmond
Gold - Posts: 4,610
Posted: January 10, 2015 at 6:32 PM / IP Logged
You have to do this on both vehicles. Each system holds 3 remotes, therefore if you program 4 remotes the first remote gets bumped from the system
Ted
Compustar Expert
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
