Mitsubishi Pajero 2008 Remote start
nonnii
Posted: October 05, 2015 at 12:48 PM / IP Logged Link to Post Post Reply Quote nonnii
I'm looking for the remote starter / alarm diagram ( wire colors ) for my 2008 Mitsubshi Pajero. Thanks in advance for your help.
tonanzith
Gold - Posts: 601
Posted: October 11, 2015 at 12:21 AM / IP Logged Link to Post Post Reply Quote tonanzith
My info only goes to 2007. I believe it's the same but meter everything to be sure.
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     BLUE IN FRONT OF FUSE BOX DRIVERS SIDE 8 PIN CONN
Second 12 Volts
Starter     BLACK-YELLOW AT IGNITION SWITCH
Second Starter
Ignition     BLUE-BLACK IN WHITE 8 WAY FRONT OF FUSE BOX
Second Ignition
Third Ignition
Accessory
Second Accessory
Third Accessory
Keysense
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock     GREEN-RED     NEG     AT 24 WAY WHITE CONNECTOR AT FUSE BOX
Power Unlock     BROWN-BLACK     NEG     AT 24 WAY WHITE CONNECTOR AT FUSE BOX
Lock Motor
Driver Unlock Motor
Passenger Unlock Motor
Parking Lights (-)
Parking Lights (+)
Hazards
Turn Signal (Left)     GREEN-YELLOW PIN 5 IN 14 WAY AT FRONT OF FUSE BOX
Turn Signal (Right)     GREEN-RED PIN 14 IN 14 WAY AT FRONT OF FUSE BOX
Headlight
AutoLights
Reverse Light
Left Front Door Trigger     YELLOW-BLACK AT WHITE 15 WAY PIN 6 FRONT OF FUSE BOX
Right Front Door Trigger     YELLOW-GREEN IN 24 WAY GREY CONNECTOR AT FUSE BOX
Left Rear Door Trigger     PINK PIN 20 IN 28 WAY AT FRONT OF FUSE BOX
Right Rear Door Trigger     YELLOW-PINK IN 24 WAY GREY CONNECTOR AT FUSE BOX
Dome Supervision
Trunk/Hatch Pin     BLACK-BLUE at 24 way white connector fuse box
Rear Glass Pin
Hood Pin     FIT NEW
Trunk/Hatch Release
Trunk Release Motor
Gary Sather
Posted: October 11, 2015 at 12:26 AM / IP Logged Link to Post Post Reply Quote howie ll
Be very careful that vehicle had different names in Japan/Europe/US, Pajero, Shogun and Montero.
There might be subtle differences.
I did an 06 Land Cruiser UK spec. on Friday, UK spec and ALL the wiring except IGN 1 and starter was different, colour and location from the Directwire US crib sheet I was using.
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
