2004 F350 Viper 4706v remote start
Welcome Guest :)
ricerocketc
Member -
Posted: October 25, 2015 at 2:31 PM / IP Logged
Looking to install a viper remote start in my 04 F350 diesel. It has a factory keyless entry with alarm and no chip key. After opening the dash I noticed that the "factory" alarm is actually a code system alarm model H63DB which also has the ability to be used as a remote start as well. Because the viper is 2way I'd like to still install it, my question is will I have to remove the code system alarm/starter or can I wire the viper to arm/disarm the code security system.
viper wiring guide
h63db main harness
h63db extended harness
Moderator -
Posted: October 25, 2015 at 9:05 PM / IP Logged
Use the DISARM input (+) BROWN wire to the status putput wire from the Viper and this will disable the alarm system for the Code Alarm.
Pot Metal -
Posted: October 26, 2015 at 1:18 AM / IP Logged
Jeff you wrote disarm input (+) and connect to status output wire from Viper. But that goes to ground (-).
Regards, Howard.
ricerocketc
Member -
Posted: October 26, 2015 at 8:54 PM / IP Logged
So am I to understand this solution won't work then?
ricerocketc
Member -
Posted: October 29, 2015 at 6:57 PM / IP Logged
Anyone? I'd like to get this project going this weekend
If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum
Wednesday, May 29, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
