98 camry wiring
kkpt
Posted: December 20, 2015 at 1:11 PM / IP Logged Link to Post Post Reply Quote kkpt
Happy Sunday All,
I am KPT, new to this forum. Finding it interesting.
I am wiring a Xpresskit PKALL bypass module to my 98 XLE v6. I am doing this to wire my prostart remote starter using this bypass module.
the bypass module's diagram has few wires to connect to CLK, DATA and SYNCHRO wire from the ignition Barrel. the colour of wires as specified in the manual does not match to what is on the car.
Requesting any help that might guide to identify these wires
Thank you all, and Happy last minute shopping
KPT
kitchener, Ontario
kpt
Platinum - Posts: 7,790
Posted: December 20, 2015 at 3:31 PM / IP Logged Link to Post Post Reply Quote kreg357
Here is the transponder connector wires from iDatalink :
AMP       pin 1   BLACK / YELLOW (DATA) @ Ignition switch
Code      pin 2   GREEN / WHITE (DATA)              @ Ignition switch
RXCK    pin 3    RED / Blue (DATA)       @Ignition switch
TXCT     pin 4   Blue / YELLOW (DATA)    @ Ignition switch
Ground   pin 5  WHITE/ Black (-)   @ Ignition switch
Of course they give the wires different names, but...
kkpt
Posted: December 20, 2015 at 7:59 PM / IP Logged Link to Post Post Reply Quote kkpt
Thank you. Is there a way to identify by measuring volts or by tracing where it is?
Kpt
kpt
Wednesday, June 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
