Programming Astrostart 1105 on ’02 Tahoe
jcskeeter
Member - Posts: 11
Posted: January 13, 2016 at 9:18 AM / IP Logged Link to Post Post Reply Quote jcskeeter
Hi All -
I recently relocated the brain box to a better spot under the dash. In doing so I needed to remove all of the plugs. Including connections to the bypass module. I plugged everything back in and unfortunately the remote start part isn't functioning now. The doors lock and unlock but the factory security has gotten confused a few times now on the unlock with the remote.
I've tried to go through the programming on the brain and I've even tried to program the bypass. It all seems to be working according to the directions but when I try to remote start, I just get a click from the brain and then it doesn't start.
So my question is about programming order. If I were to pretend that I just installed this remote start, what order do I plug things in and in what order do I program everything, including the bypass?
2002 Tahoe
Astrostart 1105 w/5-button remote
GMBP BYPASSKIT from Xpresskit
Hopefully that's enough info. LMK if I forgot anything. And I seriously appreciate any direct help or if you can point me in a direction. Thanks!!
jcskeeter
Member - Posts: 11
Posted: January 13, 2016 at 11:55 AM / IP Logged Link to Post Post Reply Quote jcskeeter
Testing a theory - If there's one reply on this thread, are people more likely to click into it...
jcskeeter
Member - Posts: 11
Posted: January 13, 2016 at 8:14 PM / IP Logged Link to Post Post Reply Quote jcskeeter
Is there a different forum that people could direct me to that may be more appropriate for my question? Anything would be great! Thanks! 😀
mscguy
Copper - Posts: 212
Posted: January 13, 2016 at 9:45 PM / IP Logged Link to Post Post Reply Quote mscguy
I don't know anything about that one, but a quick google search comes up with this.
http://www.carfixin.com/file.asp?ID=466
Astrostart / Astroflex the same thing?
Also, quick search on xpresskit website comes up with this.
http://www.xpresskit.com/DocumentDownload.aspx?documentid=4389&productid=142&firmwareid=1327
jcskeeter
Member - Posts: 11
Posted: January 14, 2016 at 12:21 AM / IP Logged Link to Post Post Reply Quote jcskeeter
Hey thanks for chiming in. I actually have both of those documents. The Astrostart install instructions are about as clear as mud. Really looking for the word of mouth install rundown from a tech. If that makes sense. Thx!
jcskeeter
Member - Posts: 11
Posted: January 14, 2016 at 10:18 AM / IP Logged Link to Post Post Reply Quote jcskeeter
If this strikes a cord with anyone. When I try to remote start, the brain box clicks a relay, the led flashes rapidly for a second and then the led flashes 19 times pause 19 times and so on. If I tap the brake, the flashing stops.
In the manual, the diagnostic codes stop at 13
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
