09 Honda CRV, SL3 bypass
steve lny
Posted: March 13, 2016 at 9:41 AM / IP Logged Link to Post Post Reply Quote steve lny
Hi guys, New here...
Pick your brain. I installed a crime stopper RS4 remote start with a SL3 bypass. 09 CRV.
It worked great for a day, then the positive wire on the remote starter came loose. So I reconnected it. Rechecked current and continuity in all wiring.
Now, it'll only crank, and not start. If I stick the key in the ignition, leaving it in the off position, it'll start with the remote starter.
When I try to reprogram the SL3, the LED will not come on at all. Any ideas?
Thanks for your time.
Steve L
Platinum - Posts: 7,790
Posted: March 13, 2016 at 5:29 PM / IP Logged Link to Post Post Reply Quote kreg357
Well, I guess you could use a Digital Multi Meter to verify that the Fortin SL3 module is getting +12V and Chassis Ground
in on the CONN1 plug.  If that looks OK, my next step would be to connect the FlashLink updater to the SL3 and try to
re-flash the firmware.  That would quickly tell you if the module is dead or not.  If it is able to be re-flashed, verify all the
bypass modules connections and then try to re-program it to the CR-V.
smokeman1
Platinum - Posts: 1,588
Posted: March 13, 2016 at 6:38 PM / IP Logged Link to Post Post Reply Quote smokeman1
I would wonder, if the positive wire came loose, are the wires soldered or just crimped. Maybe something else is loose.
steve lny
Posted: March 14, 2016 at 6:40 AM / IP Logged Link to Post Post Reply Quote steve lny
Thanks guys.
I did check and see if the sl3 was getting pee and ground. 12.76 volts. Ground is good.
The only writing that's crimped are the ones to the ignition harness under the column. Everything else is suffered and continuity tested.
When is the LED on the SL3 supposed to be on?
Because it doesn't come on at all. Not even if I try to reprogram it.
Steve L
steve lny
Posted: March 14, 2016 at 6:42 AM / IP Logged Link to Post Post Reply Quote steve lny
Correction to above since I can't edit.
I did check to see if the unit is getting power and ground, with a multimeter.
Steve L
rs specialist
Copper - Posts: 175
Posted: March 14, 2016 at 1:53 PM / IP Logged Link to Post Post Reply Quote rs specialist
So when you unplug the SL3 are you holding the button in on the module?
steve lny
Posted: March 14, 2016 at 2:04 PM / IP Logged Link to Post Post Reply Quote steve lny
No. Should I hold the button while unplugging?
And I held the blue wire from the 8 pin plug to ground, the LED never comes on.
Steve L
Thursday, June 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
