99 F350 starts but will not continue to run
northern
Copper - Posts: 154
Posted: November 20, 2016 at 5:45 PM / IP Logged Link to Post Post Reply Quote northern
99 F350 install. Autostart 2 Way LCD with virtual tach.
No chip in key
Hooked up 12 volts to Yellow wire
Ign to Larger RED / black
Hooked up accessory to gray / YELLOW
hooked up second accessory wire to first the black with green stripe and did not work, so used smaller RED / black stripe.
RED / light blue is the starter wire.
Vehicle remote starts, runs for 5 seconds shuts off, starts again, runs 5 seconds shuts off, starts 3rd time runs 5 seconds shuts off, normally you get a flash code to tell you why it failed, it does not do that.
pentavolvo
Copper - Posts: 241
Posted: November 20, 2016 at 6:19 PM / IP Logged Link to Post Post Reply Quote pentavolvo
Did you learn the tach
northern
Copper - Posts: 154
Posted: November 20, 2016 at 6:59 PM / IP Logged Link to Post Post Reply Quote northern
These units are tachless
bat9905
Copper - Posts: 131
Posted: November 20, 2016 at 11:22 PM / IP Logged Link to Post Post Reply Quote bat9905
Grab tach behind instrument cluster . I believe these have to have reliable tach source
bat9905
Posted: November 21, 2016 at 9:08 AM / IP Logged Link to Post Post Reply Quote howie ll
5 - 15 seconds usually a positive indication of no tach.
davep.
Gold - Posts: 643
Posted: November 21, 2016 at 2:41 PM / IP Logged Link to Post Post Reply Quote davep.
Being an F350, I assume this is a 7.3 Diesel. If it's a gasser, Ignore the rest of this post, I don't know much about the gassers.
In a 99 Powerstroke you can get the tach in the harness under the "S" shaped cover just to the inboard side of the PCM, outboard of the brake pedal. Going from memory, and I double-checked it on my wiring info, it is wht/pnk.
northern
Copper - Posts: 154
Posted: November 23, 2016 at 2:00 PM / IP Logged Link to Post Post Reply Quote northern
It is a diesel. I have done hundreds of these and never have done tach on the newer autostart models(models after the 2300itw and after. I will try it
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
