2013 Nissan Murano Factory Alarm
dpossick
Posted: March 21, 2018 at 10:27 PM / IP Logged Link to Post Post Reply Quote dpossick
My factory alarm is randomly going off- seems to happen more in cold weather. Anyone have a diagnostic method? I was considering disabling sensors one at a time and see if problem is eliminated- problem is- I have no ideal where alarm is housed, where sensors or if disabling alarm/sensors will disable ignition.
FYI- I already replaced batteries in smart keys and tried disabling them by leaving without batteries all together.
Also- I have a sneaking suspicion it may be power liftgate related. Liftgate open light flashed on/off a few times last week while driving(It was closed and locked)
Thanks in advance for any help.
eguru
Copper - Posts: 340
Posted: March 22, 2018 at 7:12 AM / IP Logged Link to Post Post Reply Quote eguru
The alarm is not affected by the condition of the batteries in the fobs
However, a marginal car battery can often cause wierd and random electronic issues and cold weather will make them worse.
Are you still on the original battery? If so, you might consider changing it as it is overdue.
dpossick
Posted: March 22, 2018 at 7:17 AM / IP Logged Link to Post Post Reply Quote dpossick
Thank you, I forgot to mention I already put a new battery in and problem still exist.
mgoetz74
Silver - Posts: 424
Posted: March 22, 2018 at 10:54 AM / IP Logged Link to Post Post Reply Quote mgoetz74
check your door pins. I have had from time to time Nissans with bad door pins come in for the same reason. I owned a 03 xterra that I had to change both the front door pins for the same thing. kinda a know issues along with the knock sensors going out in nissans
dpossick
Posted: March 22, 2018 at 10:59 AM / IP Logged Link to Post Post Reply Quote dpossick
Thanks- will check!
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
