CM7200 Remote Start, 2013 Mazda CX-5
spudwink
Posted: October 03, 2018 at 6:49 PM / IP Logged Link to Post Post Reply Quote spudwink
I have a CM7200 remote start module that I want to install in a 2013 Mazda CX-5, push-to-start, automatic.
1) Does any one know if this vehicle uses low current ignition wires.
2) If the Mazda CX-5 does use low current, can I use the high current harness instead without causing damage/problems, because I don't have a low current harness for my CM7200.
sand33p_sidhu
Member - Posts: 25
Posted: October 10, 2018 at 12:40 AM / IP Logged Link to Post Post Reply Quote sand33p_sidhu
You DO NOT need low current wires. Use main harness to connect your 12V, Ignition, Starter, Accessory wire.
Wednesday, June 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
