2010 Subaru Forester, Evo-All, Python 4105 Only Starts w/Key in Ignition
ahartung
Posted: December 09, 2018 at 4:28 PM / IP Logged Link to Post Post Reply Quote ahartung
2010 Subaru Forester automatic. Evo-All and Python 4105 remote start.
The car will not remote start without the key in the ignition. It will go through the process, but the starter never engages. I've checked that the IMO Data wires are properly connected before and after the cut. Checked voltage on all CAN connections.
Evo programmed correctly as far as I can tell. Units connected via datalink cable, D2D protocol programed for Evo. Remote start key fob operates locks correctly, but OEM fob not working.
Obviously something is wrong with the bypass, but I don't know what to check next.
Platinum - Posts: 7,789
Posted: December 09, 2018 at 6:13 PM / IP Logged Link to Post Post Reply Quote kreg357
By EVO-ALL in D2D protocol, you checked the F3 Option box during the flash process?
Did you make the IGN1 hardwire connection from the 4105 to the EVO-ALL Pin A-1?
ahartung
Posted: December 09, 2018 at 7:05 PM / IP Logged Link to Post Post Reply Quote ahartung
Correct.
Yes.
Posted: December 10, 2018 at 6:17 AM / IP Logged Link to Post Post Reply Quote kreg357
Good so far.
Double check that the EVO-ALL Light Blue/Black wire at A-10 is connected to correct ( away ) side of the cut IMO DATA wires at the BCM connector.
The DCryptor part of the module programming went OK, too?
ahartung
Posted: December 10, 2018 at 8:28 PM / IP Logged Link to Post Post Reply Quote ahartung
I went through and checked every connection again, don't know what I did, but it now works.
One odd thing though, after remote starting, the diver's side headlight is on, but the passenger's isn't. It is only as bright as daytime running lights, not full. I was testing it at night. Lights were normal when key started, off.
Posted: December 11, 2018 at 6:30 AM / IP Logged Link to Post Post Reply Quote kreg357
Maybe a connector was loose somewhere. I always solder all my connections, never an issue.
With the Parking Lights, make sure the 4105 is set to (-) Parking Light output via the jumper and/or try going to the Black/White wire at the Headlight switch in the steering column.
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
