2005 Neon SRT4, Excalibur Remote Start
benzo33
Copper - Posts: 87
Posted: December 07, 2019 at 1:12 PM / IP Logged Link to Post Post Reply Quote benzo33
Hi. I purchased an Excalibur al 1870 remote start with idatalink ads al ca bypass. I am having an issue of it not starting. I verified the clutch wire(red/yellow) reads 12 volts and ground when the clutch is depressed. When I activate the rs, the bypass flashes 3 times. However it does not start. Please help. Tia.
2001 Corolla S and 2005 Neon SRT 4 ACR.
mgoetz74
Silver - Posts: 424
Posted: December 07, 2019 at 3:14 PM / IP Logged Link to Post Post Reply Quote mgoetz74
is it even designed to work with a manual transmission? I've never heard of this brand but looks like a firsttech made RS which firsttech has come out against support on manual transmissions. Only DEI (viper) truly support manual transmission. It can still be done with a relay and the second starter output wire but then you have a run away train if left into gear or you leave the window done and someone reaches in and sticks it in gear. Before you say " i never leave the car in gear" (heard 1000 times) it only takes once. That would be a big pass for me, not a fan of RS in manual transmissions.
benzo33
Copper - Posts: 87
Posted: December 09, 2019 at 8:32 PM / IP Logged Link to Post Post Reply Quote benzo33
This rs has manual tranny reservation mode.
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
