Viper 5906v, Idatalink ADS ALCA Installation, 2008 Chevrolet Tahoe
tydfan13
Posted: April 06, 2020 at 3:13 AM / IP Logged Link to Post Post Reply Quote tydfan13
I am installing a viper 5906v and an idatalink ads alca bypass in a 2008 Chevrolet Tahoe and I need to know what connections I have to make. I am also installing 530t window module, and a 508d sensor. I'm not new to automotive wiring just new to this type. Any and all help will be greatly appreciated, thanks.
Jeremiah
lectricguy
Copper - Posts: 359
Posted: April 06, 2020 at 10:51 AM / IP Logged Link to Post Post Reply Quote lectricguy
For the Viper 5906v and the ALCA, follow the wiring exactly on the ALCA guide, wiring Type 2.   Here is a link to the guide: https://images.idatalink.com/corporate/Content/Manuals/DL-GM10/DBI-AL(DL)-GM10-EN_20200320.pdf.    Assuming that the ALCA has been programmed already for D2D (DBI) protocol, correct firmware is DBI-AL(DL)-GM10.
The only other connections you may need are Horn/Siren/Parking Lights/Tachometer.
Wiring reference (Tahoe model years 2007-2014 are the same): https://www.the12volt.com/installbay/forum_posts.asp?tid=140917
Viper 5906v Programming: At a minimum, you will need to configure the 5906v to Automatic transmission (Default is Manual), and desired Remote Start runtime. You'll also need to perform a tach learn.
Viper 5906v Manual: https://www.the12volt.com/installbay/downloads.asp?srch=all&term=viper+5906
For 508D, it plugs into the Sensor 2 port. Please refer to the following post: https://www.the12volt.com/installbay/forum_posts.asp?tid=132313
Hope this helps.
Lectric Guy
tydfan13
Posted: April 07, 2020 at 12:17 AM / IP Logged Link to Post Post Reply Quote tydfan13
Thank you so much, I never expected to get info so fast. Would wiring the idatalink and the alarm in D2D be the Best option or should I wire it all direct. I only ask because I'm a worry wort and want the best outcome possible. Other than the ease and time involved is there any clear advantage of 1 over the other. Thanks again for your help, have a great evening.
Jeremiah
lectricguy
Copper - Posts: 359
Posted: April 07, 2020 at 8:16 AM / IP Logged Link to Post Post Reply Quote lectricguy
Both methods will work in this application, but the caveat is that the ADS ALCA must programmed with the proper firmware (DBI-AL(DL)-GM10), to use the D2D method. If the ALCA is programmed with ADS(idatalink) protocol (ADS-AL(DL)-GM10), you will need to use wire to wire with the Viper 5906v.
D2D is my install method of choice, but there is nothing wrong with wire to wire. If you choose Wire to Wire, careful bench prep will allow for a cleaner install with this method.
Lectric Guy
tydfan13
Posted: April 09, 2020 at 2:22 AM / IP Logged Link to Post Post Reply Quote tydfan13
Thanks again friend. I've been trying to get all this info for months now and a buddy turned me on to this site, so thankful for you guys and or gals on here. This is what it's all about, everybody helping each other. Again thanks and have a great evening and stay safe.
Jeremiah
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
