1985 Chevrolet Camaro, Automatic Transmission, Viper 5305V
wyciwug
Copper - Posts: 156
Posted: April 17, 2022 at 8:07 PM / IP Logged Link to Post Post Reply Quote wyciwug
HELLO
i am attempting to inatall Viper 5305v Combo System.. I wonder of there is anything special that I need to know before installation?
I Assume I do not need bypasa for the remote start?
THANKS
dcd
Platinum - Posts: 13,676
Posted: April 18, 2022 at 1:29 PM / IP Logged Link to Post Post Reply Quote i am an idiot
If this is your key, actions need to be taken. If your key does not have the resistor blister, no action needed.
https://www.americankeysupply.com/product/gm-single-sided-vats-key-p1-15-w-gm-logo-strattec-3133?utm_medium=adwords&%3Futm_campaign=&utm_source=&utm_content=&utm_term=&gclid=Cj0KCQjwmPSSBhCNARIsAH3cYgYJuZhuIdNStXnuM5jinfqgPqJ-tyij9KeVF_Q6NCvyx3JUhwyvkFYaAnyrEALw_wcB&follow_links=1
wyciwug
Copper - Posts: 156
Posted: April 18, 2022 at 1:45 PM / IP Logged Link to Post Post Reply Quote wyciwug
IT has no resistor, only a metal blade plain key
dcd
Platinum - Posts: 7,790
Posted: April 18, 2022 at 5:11 PM / IP Logged Link to Post Post Reply Quote kreg357
Carb or F.I.?
wyciwug
Copper - Posts: 156
Posted: April 18, 2022 at 5:34 PM / IP Logged Link to Post Post Reply Quote wyciwug
SIR
it is Fuel Injector
dcd
Posted: April 18, 2022 at 5:57 PM / IP Logged Link to Post Post Reply Quote kreg357
Good, F.I. is expected with remote start systems as there is no easy way to set the carburetors' choke or pump the gas pedal...
wyciwug
Copper - Posts: 156
Posted: April 18, 2022 at 6:09 PM / IP Logged Link to Post Post Reply Quote wyciwug
So just straight away follow diagam from directwires?
NO bypass needed for Remote start?
dcd
Posted: April 18, 2022 at 8:34 PM / IP Logged Link to Post Post Reply Quote kreg357
Pretty much. Some minor issues to deal with.
1. Factory Power locks are (+) and Viper lock outputs are (-). Get a 451M module to handle the conversion.
2. Run in Tach Mode using Tach Signal from coil.
3. Parking Lights are (+) so set Viper 5305 to output (+) Parking Light output via fuse/jumper.
4. There are two ACC ignition wires, Orange & Brown. Set the Viper Pink/White to ACC2 and use it.
5. If the Camaro has a trunk light use it as the Trunk Pin source.
6. If the door pins still work you can use the Dome Light wire as the Viper All Door Pin Input.
If the ignition key does not have the VATS resistor chip on it, no need for a bypass module. You mentioned a plain metal key so you should be good to go.
Wednesday, June 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
