Starter Bypass And Mobile Solution With No Manufacturer Login?
labe0202
Member - Posts: 10
Posted: November 16, 2022 at 11:20 AM / IP Logged Link to Post Post Reply Quote labe0202
Hello. I'm a former installer from many years ago (Circuit City era 15+ years ago). I'm completely out of the game and have very little experience with modern CAN BUS type bypasses. Is there any way for someone to install a remote start with a mobile solution (SmartStart, DroneMobile, etc.) without a login to DirecTechs, etc.? My car is a manual transmission 2018 Subaru Impreza with a normal key start. I'm confident I could handle the install, however if I can't get a flashed bypass or activated mobile solution module it won't really matter. Is it possible for someone who isn't associated with an authorized retailer to do this anymore or are those days over? Many thanks.
silvercivicsir
Copper - Posts: 409
Posted: November 16, 2022 at 11:52 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
anybody can get a idatalink log in to flash their products, however you also have to buy their flashing tool. same goes with Fortin.. only Directechs makes you buy a certain amount every quarter to enable you to flash their product
labe0202
Member - Posts: 10
Posted: November 16, 2022 at 9:06 PM / IP Logged Link to Post Post Reply Quote labe0202
Alright, great to know. Thanks. Would I be able to activate the DroneMobile myself too?
labe0202
Member - Posts: 10
Posted: November 16, 2022 at 9:11 PM / IP Logged Link to Post Post Reply Quote labe0202
Also, I’m having trouble finding a Compustar that is compatible with a manual. The most common ones I find online say they’re automatic only. These are the CS4900-AS, CS7900-AS, and others. It used to be that a CS would be auto or manual depending on whether the loop was cut. Doesn’t seem to be the case anymore.
mgoetz74
Silver - Posts: 424
Posted: November 17, 2022 at 1:49 PM / IP Logged Link to Post Post Reply Quote mgoetz74
you can use anything that doesn't have a dc3 brain (4900skit rs1b20dc3 ect.). You'll have to get a blade bypass module which is a dead give away that it not a dc3. dc3 does not work with manual transmissions
https://www.amazon.com/Compustar-CS8900-AS-Security-Bundled-Blade-AL/dp/B08SMRW51J/ref=sr_1_40?crid=QOCUNEEJV5SR&keywords=compustar+remote+start&qid=1668714680&sprefix=compustar%2Caps%2C211&sr=8-40
labe0202
Member - Posts: 10
Posted: November 17, 2022 at 8:38 PM / IP Logged Link to Post Post Reply Quote labe0202
Appreciate the reply. I checked out the bundle you linked, which is exactly what I’m looking for. The Compustar site says this bundle and the other bundles listed on Amazon use the CM900-AS brain. The install manual for the CM900 says “The CM900S/AS are for Automatic transmission vehicles ONLY.” Maybe I’m misunderstanding something here?
Platinum - Posts: 7,790
Posted: November 17, 2022 at 9:11 PM / IP Logged Link to Post Post Reply Quote kreg357
Look for a Compustar FT7200-s controller. Compustar StartIt FT-7200S
It uses the Blade cartridge. You will need a Remote Kit that comes with remotes, antenna and antenna harness. There are many kits available depending on needed range and one or two way communication.
The FT7200-s can also handle Drone ( phone app ) control.
Additional info :
Clutch (+) Light Green at clutch pedal White 10 Pin connector, Pin 9
silvercivicsir
Copper - Posts: 409
Posted: November 18, 2022 at 9:10 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
7200 has been discontinued , the new one is a CMX
silvercivicsir
Copper - Posts: 409
Posted: November 18, 2022 at 9:12 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
another option for telematics is Mycar if you are in Canada, or Carlink
labe0202
Member - Posts: 10
Posted: November 18, 2022 at 1:03 PM / IP Logged Link to Post Post Reply Quote labe0202
All sounds good, thanks again. Seems like the CMX is definitely easier to find.
Monday, June 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
