97 sunfire alarm help!
Spamme
Member - Posts: 6
Posted: August 23, 2003 at 10:32 PM / IP Logged
can anyone help me find the dome light wire. i was reading a website and on their diagram it said it was the Lt. GREEN/ black wire located at the "convience center mod."  can anyone lead me in the right direction to where that may be??
Platinum - Posts: 12,488
Posted: August 23, 2003 at 10:50 PM / IP Logged
The GREEN/ black is located in the lower drivers kick panel.  It catches the drivers door only.  The light blue is located in the lower passenger kick panel, and catches the passenger door(s).  Tap both wires and diode isolate each.
Spamme
Member - Posts: 6
Posted: August 23, 2003 at 10:56 PM / IP Logged
i did that, and the door triggers work fine, but when i unlock the doors, the lights wont come on. i never dioded the wires, woudl that cause the lights not to come on. because the triggers work fine without diodes.
thanks
Spamme
Member - Posts: 6
Posted: August 23, 2003 at 11:02 PM / IP Logged
is there anyway to bypass the passlock 1 system without buying the module. im trying to get the remote start feature on my hornet dei 554t alarm. i have 1997 sunfire gt.
thanks
Posted: August 23, 2003 at 11:13 PM / IP Logged
How did you hook up the relay for the dome light circuit ? Use this diagram for the (-) trigger dome light circuit.
Spamme
Member - Posts: 6
Posted: August 23, 2003 at 11:19 PM / IP Logged
ok thanks.
one more question. if i hook up the dome supervision from my alarm to the door trigger wire from my cars harness, wont that work for my dome light.
might be a stupid question, but i had to ask
thanks
Posted: August 24, 2003 at 7:43 AM / IP Logged
Yes it will.
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
