Immobilizer 2
roncoleman11
Member - Posts: 41
Posted: February 02, 2004 at 3:55 PM / IP Logged
does anybody know how to hook up a 555u to a 4 wire immobilizer? for a dodge Ram
daniel2002p
Silver - Posts: 524
Posted: February 02, 2004 at 4:16 PM / IP Logged
dont understand what you are trying to do hook up a 555u to a alarm????
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
roncoleman11
Member - Posts: 41
Posted: February 02, 2004 at 4:32 PM / IP Logged
i am trying to hook up a 555u to a immobilizer that has four wire's going to it, and i dont know which ones to hook the 555u to.
NowYaKnow
Gold - Posts: 1,217
Posted: February 02, 2004 at 6:18 PM / IP Logged
Unless they have changed the 555u, all you do is put a spare key in the 555u box, and put the ring around the transponder ring @ the ignition cylinder. You don't tap into any of the wires up at the ignition cylinder. The red wire from the 555u will go to 12v constant fused. The blue wire from the 555u will go to the negative ignition 3 output or active out depending on what your installing. The white wire from the 555u is not used. Good luck,
Mike
Sunday, November 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
