keyless entry
sluf12
Posted: July 05, 2004 at 4:45 PM / IP Logged
keyless entry -- posted image. I`AM WORKING ON A 2003 KIA SEDONA REMOTE START AND KEYLESS ENTRY. CAN`T LOCATE THE WIRES FOR THE DOOR LOOK MOTORS.ANYONE GOT THE ANSWER?
blue one
boomer_106
Silver - Posts: 710
Posted: July 05, 2004 at 5:05 PM / IP Logged
Yep sure do.
Kia
Sedona
2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK / YELLOW to Yellow (+)
Ignition switch harness
Ignition  #1:
WHITE/ Blue to White (+)
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
Green (+)
Brake  Light:
White (+)
Brake pedal switch
Tach  Signal:
Yellow/Red (AC)
Instrument cluster left plug*
Parking Lights:
RED / Black (+)
Drivers kick harness to the rear
Headlights:
N/A
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 *Can also use Green at ignition coil under engine cover.
Kia
Sedona
2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
Red & BLACK/ Red (+)
Starter  Kill:
Ignition  +12 Volts:
Dome  Lights/Superv:
WHITE/ Red (-)
Top of fuse box
OEM Horn:
Yellow/White (-)
Steering column harness
Power  Lock:
WHITE/ Black (-)
Plug left of steering column**
Power  Unlock:
RED / Green (-)
Trunk  Release:
N/A
Alarm  Input Wire:
WHITE/ Red (-)
Top of fuse box
Notes:
**See Note #201 Negative Trigger Door Locks
sluf12
Posted: July 05, 2004 at 6:08 PM / IP Logged
WE`LL GIVE IT A TRY. THANKS FOR THE INFO.
blue one
boomer_106
Silver - Posts: 710
Posted: July 05, 2004 at 6:12 PM / IP Logged
You're Welcome
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
