2004 BMW 325xi, alarm wiring
Memphisman
Copper - Posts: 161
Posted: August 03, 2004 at 5:00 PM / IP Logged
Anybody have a wiring diagram for this car? I mainly need the lock, unlock, and power wires so I can hook up a relay to honk the horn and flash the lights.
plazaman
Posted: August 12, 2004 at 5:58 PM / IP Logged
Why not go with the OEM Alarm?
cva2000uk
Copper - Posts: 60
Posted: August 12, 2004 at 6:46 PM / IP Logged
Ive not done one, but ive heard they are not much different to the previous model.
has the cobra site not got one?
italian site but in english also
mxxmikexx
Silver - Posts: 796
Posted: August 12, 2004 at 8:01 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - BMW / 3 SERIES / 2004 / Security
[PRINT THIS PAGE]
12volts RED / green and RED / blue   +   ignition harness
Starter BLACK/ blue   +   ignition harness
Ignition green   +   ignition harness
Power Lock blue/red   -   54 pin plug, pin 22 at general mod
Notes: The general module is a white box located behind the glove box. The 54 pin plug is the center plug, and the 26 pin plug is the one on the left.
Power Unlock WHITE/ black   -   54 pin plug, pin 20 at general mod
On some models, unlock may require a double pulse.
Lock Motor white (any one of 5)   5wi 54 pin plug at general module
Unlock Motor blue   5wi 54 pin plug, pin 35 at general mod
Disarm Defeat (chassis ground)
Parking Lights+
Parking Lights- see notes
Notes: Need to remove the light switch module from the dash and pop off the front cover. A ribbon cable which connects the switch to the module will be exposed. With the switch facing towards you, you need to interrupt the fourth wire from the left with a relay. When interrupted the parking lights will comes on. See DirectFax document 1055 for wiring information.
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger RED / blue   +   54 pin plug, pin 18 at general mod
Dome Supervision comes on with unlock
Trunk/Hatch Pin WHITE/ brown   -   driver kick panel
Hood Pin PURPLE / green   -   26 pin plug, pin 7 at general mod
Trunk/Hatch Release gray/green   +   54 pin plug, pin 17 at general mod
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer black   ac   diagnostic plug
Notes: The diagnostic plug is on the passenger side of the engine compartment. If the vehicle does not have the diagnostic plug then the black wire can be found at the data link connector under the driver side dash.
Horn Trigger PURPLE / blue   +   horn relay
Notes: The horn relay is above the general module. It is the green relay to the right of an orange relay.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: EWS III Part #: 556U or 555B
Notes: See DirectFax document 1056 for additional wiring information.
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
