2 door central lock kit
sn0rky
Member - Posts: 9
Posted: August 17, 2004 at 9:17 PM / IP Logged
i have 2 door central lock kit.. n i was wonderin how do i add extra actuators because i have a 4door car
mo12v
Posted: August 17, 2004 at 9:22 PM / IP Logged
You need 2 more -2 wire acuators- for rear doors and, depending on your lock kit brand, you should be able to wire directly to Lock/Unlock Relay or to Lock/Unlock wires on front doors
MO
auex
Platinum - Posts: 5,041
Posted: August 17, 2004 at 10:58 PM / IP Logged
You may be able to tie into the existing wiring for the lock motors. But you should check the fuse for the lock relays prior to doing so.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
