Turbo Timer and Alarm
customcarelectr
Member - Posts: 43
Posted: August 17, 2004 at 11:25 PM / IP Logged
just put a turbo timer on a 2004 wrx with a remstart alarm , turbo timer keeps power to ignition for countdown period , which does not allow the owner to arm his alarm?
any thoughts on how i can make these two work together
auex
Platinum - Posts: 5,041
Posted: August 17, 2004 at 11:28 PM / IP Logged
Set alarm to passive arming. Or you could, depending on model, do remote start take over, activate remote start with key in, then arm. You could also probably use the remote start as a turbo timer.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
customcarelectr
Member - Posts: 43
Posted: August 18, 2004 at 1:06 AM / IP Logged
yes but if he wants to run timer for more than the 30 seconds or so that passive armng allows, then what?
That is a good idea but are there any actuall solutions for both to work without interfering with eah other??
profuse007
Gold - Posts: 2,015
Posted: August 18, 2004 at 1:29 AM / IP Logged
what type of alarm do you have?
Houston,TX
jimmeezgolfvr6
Silver - Posts: 258
Posted: August 18, 2004 at 5:58 AM / IP Logged
open up the ignition wire and rewire it to a relay so as to isolate the key side and the engine side. connect the turbo timer to engine side and the alarm to the key side.
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
