2000 Ford Mustang remote start
redzonline
Member - Posts: 6
Posted: August 20, 2004 at 2:58 PM / IP Logged
I have a 2k  ford mustang and I hooked up the remote start and all it does is keep turning the starter over. Is there anyone who can help? there is no chip on the factory key. any help appreciated
redzonline
Member - Posts: 6
Posted: August 20, 2004 at 3:16 PM / IP Logged
I have heard that I need a transponder bypass, anyone?
anyone?
please?
snguyen
Silver - Posts: 281
Posted: August 20, 2004 at 3:22 PM / IP Logged
You will need to bypass the Ford PATS passive anti theft systems when remote starting.
thanks,
 Shawn
redzonline
Member - Posts: 6
Posted: August 20, 2004 at 3:31 PM / IP Logged
thanks for confirming that is there any way I can get the wire colors out ya? I plan on ordering a bypass kit from Omega. have you used them?
snguyen
Silver - Posts: 281
Posted: August 20, 2004 at 6:11 PM / IP Logged
For the bypass try www.bypasskit.com
slicksam
Copper - Posts: 291
Posted: August 20, 2004 at 6:14 PM / IP Logged
you need a key to get that car to remote start.
try this....leave the key in the ignition barrell...and press the remote.....it should work....then you will know you need a bypass kit for that car.
if you think it does not need a key.....check your igniton wire and ACC wire, sounds like you have them mixed up
Let me know
Slicksam
slicksam
Copper - Posts: 291
if you think it does not need a key.....check your igniton wire and ACC wire, sounds like you have them mixed up,
Let me know
Slicksam
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
