ungo sr5000 help
angus106
Posted: August 24, 2004 at 10:30 PM / IP Logged
i want to install a 2 door popper kit when i install the alaram... what channel would be the best channel to use?  i was thinking the channel 4 output would be best... i was hoping that i could use the method of wiring relays in series to controll 2 outputs on one channel would work for me?  will it?
i want to keep as many of the aux outputs available as possible b/c i would liek to add a sliding ragtop power roll up kit to it, and maybe some other stuff as well...
any advise as to how i can wire this up dofferently or if i can use the setup mentioned above would be greatly appreciated...
oh yeah is there a channel expander kit that will work with this alarm (and where can i find it?)
peace angus
angus106
Posted: August 24, 2004 at 10:32 PM / IP Logged
sorry repost please delete   last time it said there was an error and it would not post it.....
my apologies.
draasch
Gold - Posts: 2,172
Posted: August 24, 2004 at 11:52 PM / IP Logged
if you put both door poppers on one channel, then they both wil pop open when you use that channel.......
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
