parking lights...
vern.chao
Posted: October 29, 2004 at 9:53 PM / IP Logged
well i taped into the RED / green wire on the steering column but when i turn on my alarm or when my alarm goes off the lights dun't blink...i have no ideal why this is not working so anybody have any help please tell me...
oh yeah is there suppose to be a fuse on the wire that is being taped into the RED / green because i got my alarm and it came with a fuse on that wire...so let me know guys/gals
thank you
Musicman5000
Member - Posts: 17
Posted: October 30, 2004 at 12:35 AM / IP Logged
What are you working on,and with what alarm are you using?????????????
vern.chao
Posted: October 30, 2004 at 3:18 AM / IP Logged
i have a 1991 acura integra
python 650 alarm
which way do i turn the dual stage shock sensor...adjustment thing
it's a built in one on the brain and doesn't seem the be working that good
am i suppose to zip tie it somewhere or juss leave it laying...
i got it laying on frame under the dash right now...
boomer_106
Silver - Posts: 710
Posted: October 30, 2004 at 4:19 PM / IP Logged
I think you have alot of us confused. I suggest you zip tie the brain somewhere.  Im guessing you would turn the thing counter clockwise to make it less sensitive and clockwise to make it more sensitive but check your instructions.
Now to your light flash problem. You say the lights dont flash when the alarm goes off. The wire your looking for should be on the headlight switch. Im not familiar with the Integra so I dont know if your headlight switch is in the steering column or not.  At any rate I doubt you have the correct wire or it should be working unless the brain is defective. You should use your multimeter to monitor the RED / Green wire while you turn on the parking lights. If it goes from 0 to 12 volts then you have the correct wire. If no change is noted then you must have the wrong wire. Check that first and let us know what happens.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
