unlocks doors when ignition shuts off
jd1280
Member - Posts: 10
Posted: November 20, 2004 at 12:57 AM / IP Logged
the problem is that the car from the factory locks the doors when the car is put into gear but doesnt unlock them until you turn the key off. so i have my dei 554r all hooked up in the car and everything is working fine except when i shut the car down via remote the doors still unlock (like their designed to do) due to the fact the igition is loosing its power. is there a wire that i can hook up to send to a pulse to the unlock relay after the car is shut down?
thanks
JD
carguy411
Silver - Posts: 683
Posted: November 20, 2004 at 10:40 AM / IP Logged
which car do u have
you maybe able to go into the setting insider the ar and change it
kgerry
Platinum - Posts: 3,455
Posted: November 20, 2004 at 1:10 PM / IP Logged
this is a programmable feature.... open the owners manual and you'll learn how to program that feature off... you have 4 options when programming this feature.......  we run into this alot on the Alero's etc......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
jd1280
Member - Posts: 10
Posted: November 21, 2004 at 8:44 PM / IP Logged
thanks for the help i got it working perfectly after looking in the cars owners manual. I just realized that i forgot to put that it was an alero in my original post,  so you were right on kgerry thanks again.
JD
