Crimestopper remote start
Jmorton
Member - Posts: 9
Posted: December 11, 2004 at 4:21 PM / IP Logged
I recently got a used Crimestopper remote start system.  I'm trying to test it before installing it and I'm not gatting any signal on the starter wire after hiting the start buttons on the remote.  Should I get a constant 12v or just a burst?  Am I correct in thinking I can test it this way or does everything have to be hooked up for the system to work?
ksutton
Copper - Posts: 94
Posted: December 11, 2004 at 8:42 PM / IP Logged
you should get a 1-2 second 12v pulse
lspker
Silver - Posts: 503
Posted: December 11, 2004 at 9:08 PM / IP Logged
You may not get start signal until you program tach.  Check if your getting light flashing code for no tach.
furredoutgixxer
Member - Posts: 35
Posted: December 11, 2004 at 10:12 PM / IP Logged
also check and make sure the wait to start wire is taped off. (might be labeled glow plug)
Jmorton
Member - Posts: 9
Posted: December 16, 2004 at 2:32 PM / IP Logged
So I should probably go ahead and install it and hope it works?
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
