04 Honda CR-V Alarm/Remote Start Wiring
Acuraxtasy
Member - Posts: 45
Posted: February 10, 2005 at 8:02 PM / IP Logged
In need of 04 Honda CRV wiring diagram if it is available......THKS
thepencil
Gold - Posts: 1,526
Posted: February 10, 2005 at 9:08 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - HONDA / CR-V / 2004 / Remote Starter
12volts white (50A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter N/A
Ignition BLACK / YELLOW   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red   +   ignition harness
Second Accessory WHITE/ red   +   ignition harness
Keysense RED / white   -   ign harn or factory alarm plug
Notes: The factory alarm plug is a green plug to the left of the steering column.
Power Lock WHITE/ blue   -   driver kick, door harness
Power Unlock WHITE/ green   -   driver kick, door harness
Lock Motor yellow/black   5wi DKP or back of fuse box, top left
Unlock Motor YELLOW /GREEN   5wi DKP or back of fuse box, top left
Parking Lights+ RED / black   +   back of fuse box, top middle
Notes: Can also use RED / yellow (+) at the front of the fuse box, 18 pin plug, pin 15.
Parking Lights- blue   -   switch or factory alarm plug
Hazards same as turn signal wires
Turn Signal(L) GREEN/ red   +   steering column
Turn Signal(R) GREEN/ YELLOW   +   steering column
Reverse Light GREEN/ black   +   frt of fuse box, 18 pin plug, pin 1
Door Trigger grn (driver) and lt. grn/red   -   frt of fusebox or factory alarm plug
Notes: Use both wires and diode isolate each.
Dome Supervision GREEN/ red   -   back of fuse box, top right
Trunk/Hatch Pin red and GREEN / WHITE (glass)   -   frt of fusebox or factory alarm plug
Hood Pin yellow/red   -   pin switch or factory alarm plug
Trunk/Hatch Release BLACK / YELLOW   -   driver kick, door harness
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue   ac   test tachometer connector
Notes: The test tachometer connector is a two pin connector behind the battery.
Wait to start N/A
Brake Wire WHITE/ black   +   brake pedal switch
Parking Brake GREEN/ orange   -   Immobilizer Control Unit, pin 4
Notes: The Immobilizer Control Unit is on the ignition key cylinder.
Horn Trigger orange   -   column or factory alarm plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 555i, 556U, or 555U
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.04 Honda CR-V Alarm/Remote Start Wiring -- posted image.
Acuraxtasy
Member - Posts: 45
Posted: February 11, 2005 at 4:01 AM / IP Logged
Thanks......
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
