Viper 791 Cranking time
tacoma05
Member - Posts: 11
Posted: February 14, 2005 at 12:14 PM / IP Logged
Can you program the 791 to crank for a longer period of time?  The amount it is set for now, usually won't start the car in the morning.......
2005 Tacoma V6 DC/SB
Rizzysi
Member - Posts: 13
Posted: February 14, 2005 at 12:52 PM / IP Logged
Yes you can throught the programming menu.  If you don't have the install guide or user's manual, let me know and I'll post what to do.
profuse007
Gold - Posts: 2,015
Posted: February 14, 2005 at 1:37 PM / IP Logged
crank time is use for tachless model only. if youre using tach sense, then you either need to sucessfully learn it or get another source.
crank time is in menu 3-5
Houston,TX
diabloscope
Member - Posts: 48
Posted: February 15, 2005 at 1:39 AM / IP Logged
make sure you got the right tach, and like ( profuse007 )said above make sure you learn tach sucessfully   the three i have done didnt have to change a bit , but i also live in Cali.
Rizzysi
Member - Posts: 13
Posted: February 15, 2005 at 5:14 AM / IP Logged
Is it set up to read tach?
dare_ds69
Silver - Posts: 419
Posted: February 15, 2005 at 6:40 AM / IP Logged
try to progran tach again, in some cars like jeep cherocke you have to put longer period of crank .
how own your mind, control your life.
MECP certified. always use a DMM
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
