Adding piezo to alarm
Blacktj
Member - Posts: 12
Posted: April 19, 2005 at 4:51 PM / IP Logged
Hello folks, it's the annoying noob again :)
I have a Clifford Concept 600 Alarm, and I read in the wiring specs that there is a Yellow Accessory (-) wire that I can use for air horns.  I'm assuming I can use this for my piezo as well (programmable Constant/Pulsed), but I have absolutely no idea how to take that one (-) Yellow wire and plug it into the two + and - wires on my piezo siren.
My best guess is using a relay, but from what I see on this website, those are used to convert one type of trigger into the opposite type of output:   https://www.the12volt.com/relays/page1.asp
Any type of help would be greatly appreciated.
God bless,
Tony.
mo12v
Posted: April 19, 2005 at 7:06 PM / IP Logged
U got it.................
Ground Negative side of Piezo:
1 SPDT Relay:
PIN 87 = Positive Wire to Piezo
PIN 30 = 12 Volt Positive Constant
PIN 86 = 12 Volt Positive Constant
PIN 85 = Negative (Yellow ) wire from Alarm
MO
Blacktj
Member - Posts: 12
Posted: April 20, 2005 at 1:00 AM / IP Logged
Hello MO,
Thanks for your reply.  Not sure I get it though Adding piezo to alarm -- posted image.
Where do I connect pins 30 & 86?  The diagram on this page says 12V+ Fused:
I just have no idea what to do with that wire!
Thanks,
Tony.
Blacktj
Member - Posts: 12
Posted: April 20, 2005 at 1:09 AM / IP Logged
Here's what I get so far...
85: Plug the (-) cable from the alarm
87: Plug into the (+) wire of the Piezo
Connect the (-) wire of the Piezo somewhere on the body for ground.
Do I even need pins 30 & 86?  If so, connect them together as the diagram shows, and plug them where?
Cheers,
Tony.
mo12v
Posted: April 20, 2005 at 8:35 AM / IP Logged
PIN 30 & PIN 86 go to a 12 Volt Positive CONSTANT Source in your Vehicle.  Such as the Constant source your Alarm is hooked to or a battery lead
Be sure & fuse the lead
MO
Blacktj
Member - Posts: 12
Posted: April 20, 2005 at 10:24 AM / IP Logged
Ah!  Thank you so much MO!
Any way to tell where and what color the 12 Volt ignition wire is on 2004 Wrangler TJ?
thepencil
Gold - Posts: 1,526
Posted: April 20, 2005 at 10:38 AM / IP Logged
DARK BLUE + IGNITION
DIRECTWIRE™ WIRING INFORMATION - JEEP / WRANGLER / 2004 / Remote Start
12volts pink/black (30A), red (20A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition dk. blue   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ orange   +   ignition harness
Second Accessory BLACK/ dk. green and WHITE/ pink +   ignition harness
Notes: Not required for remote start.
Keysense lt. blue   -   ignition harness
Power Lock N/A
Power Unlock N/A
Lock Motor N/A
Unlock Motor N/A
Parking Lights+ BLACK / YELLOW   +   headlight switch
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) gray (F), dk. GREEN/ red (R)   +   turn signal switch
Turn Signal(R) tan (F), BROWN / red (R)   +   turn signal switch
Reverse Light PURPLE / black   +   driver kick, gray 40 pin plug
Door Trigger tan (D), tan / YELLOW (P)   -   driver kick, gray 40 pin plug
Notes: Use both wires and diode isolate each.
Dome Supervision yellow   -   driver kick, gray 40 pin plug
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT dk grn/lt grn, dk grn/org   ac   ignition coil or any fuel injector
Wait to start N/A
Brake Wire WHITE/ tan   +   brake pedal switch
Parking Brake gray/black   -   parking brake switch
Horn Trigger RED / yellow   -   horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
Be careful whose advice you buy, but be patient with those who supply it.Adding piezo to alarm -- posted image.
Blacktj
Member - Posts: 12
Posted: April 20, 2005 at 10:52 AM / IP Logged
Sweet!  Thank you pencil!
I was actually looking for the 12volts ignition wire.  Can I just choose between the pink/black and red wires?
thepencil
Gold - Posts: 1,526
Posted: April 20, 2005 at 10:59 AM / IP Logged
Use the pink/black. 30Amp
Blacktj
Member - Posts: 12
Posted: April 20, 2005 at 12:14 PM / IP Logged
Cool - thanks a lot.
One more question though - just want to make sure I don't blow anything up :)
I'll still need to fuse the cable coming from (12volt+ Fused) 30&86 that will plug into the pink/black cable, correct?
That should be enough of the noob for a while :)
Tony.
