671 xv dome light supervision & priority
powerven
Posted: April 25, 2005 at 12:11 PM / IP Logged
Just had Best Buy install 671 xv on '05 Dodge Ram Truck - they said you can't do priority unlock on this vehicle (vehicle did not have power locks so they installed 2 wire actuators) & they screwed up dome light supervision.  Cann't see how priority unlock (programmable feature) on 2 wire actuators wouldn't work.  Anyone have proper wiring or dodge specific inputs before I tear in to this and fix it myself (should have installed it myself)
thepencil
Gold - Posts: 1,526
Posted: April 26, 2005 at 12:13 PM / IP Logged
It's a lot of work, but than again that's not my concern. Anyways, here is the wiring diagram for your truck so that you can get the job done correclty yourself. Good luck.
DIRECTWIRE™ WIRING INFORMATION - DODGE / RAM PICKUP / 2005 / Remote Start
12volts red (40A), red (40A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink/white   +   ignition harness
Second Ignition pink/lt. green   +   ignition harness
Third Ignition pink / YELLOW (10 AWG)(3rd acc)   +   ignition harness
Notes: This wire is not required for remote start. It only provides power to the power window circuit.
Accessory dk. blue and pink/yel (16 AWG) +   ignition harness
Second Accessory pink / YELLOW (14 AWG)   +   ignition harness
Keysense PURPLE / tan   -   ignition harness
Power Lock PURPLE / dk. green   -   driver kick, door harness
Notes: Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
Can also use Directed 457C or 456L interface modules.
Power Unlock same as power lock wire
Lock Motor lt. green   5wi driver kick, door harness
Unlock Motor tan/lt. green   5wi driver kick, door harness
Parking Lights+ WHITE/ yel (L), WHITE/ gray (R)   +   harness at top of driver fender
Parking Lights- WHITE/ lt. green   -   headlight switch
Notes: Parking lights are negative trigger thru a 590 ohm resistor. MUST use a relay.
Hazards WHITE/ orange   -   hazard switch
Notes: Hazards are negative trigger thru a 120 ohm resistor. MUST use a relay.
Turn Signal(L) use hazards wire
Turn Signal(R) use hazards wire
Reverse Light WHITE/ lt. green   +   inside mirror or plug by PCM
Notes: The PCM is on the passenger side firewall.
Door Trigger see notes   -   see notes
Notes: The driver door trigger is purple and the driver side rear door is PURPLE / orange. These wires are in the driver kick panel. The passenger door trigger is PURPLE / white and the passenger side rear door is purple / YELLOW. These wires are in the passenger kick panel. Use all four wires and diode isolate each. See DirectFax document 1076 for wiring information.
Dome Supervision yellow/lt. blue or yellow/org   +   driver A pillar or cluster
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm PURPLE / lt. blue   -   driver kick, door harness
Notes: This will also do door locks. Arm/lock is negative trigger thru a 644 ohm resistor. Disarm/unlock is negative trigger thru a 1565 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays.
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock see factory alarm disarm
Tachometer dk. blue/gray   ac   PCM, orange plug, pin 34
On SRT-10 models, the tach wire is in the black plug, pin 18.
On diesel models, the tach wire is at the ECM on the lower driver side of the engine, 60 pin plug, pin 24, or at the camshaft position sensor just left of the ECM, in a 3 pin plug.
On gas models, can also go to any ignition coil or fuel injector and use the wire that is NOT BROWN / white.
Wait to start see DirectFax document 1091
Brake Wire WHITE/ tan   +   brake pedal switch
Parking Brake dk. GREEN / WHITE   -   parking brake switch
Horn Trigger dk. GREEN/ purple   -   horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
Be careful whose advice you buy, but be patient with those who supply it.671 xv dome light supervision & priority -- posted image.
gus1
Gold - Posts: 1,013
Posted: April 26, 2005 at 4:13 PM / IP Logged
You will need 2 more relays. Serperate the driver's and passenger's door actuator wires. The Driver's door wires will stay on the existing relays. The passenger's door unlock will go on the extra relays. RED / white on the main harness will be for the second unlock once programmed for it. Lock pulse will go to both sets of relays. As far as dome supervision, how is it screwed up?
Gus
Friday, June 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
