DIRECTWIRE™ WIRING INFORMATION - HONDA / RIDGELINE / 2006 / Remote Start
12volts white (50A) + ignition harness
Starter BLACK/ white + ignition harness
Second Starter N/A
Ignition BLACK / YELLOW + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow + ignition harness
Second Accessory WHITE/ black + ignition harness
Keysense RED / white - ignition harness or MICU
Notes: The MICU (Multiplex Integrated Control Unit) is part of the underdash fuse/relay box.
Power Lock pink/black - passenger kick or MICU
Meter this wire while pressing the passenger door lock switch.
Power Unlock pink/blue - passenger kick or MICU
Lock Motor
Unlock Motor
Parking Lights+ RED / black + underdash fuse/relay box
Parking Lights- blue - headlight switch
Hazards GREEN/ red + hazard switch or MICU
Turn Signal(L) RED / blue + underdash fuse/relay box
Turn Signal(R) brown + underdash fuse/relay box
Reverse Light green + MICU
Door Trigger blue/red - interior light switch on dash
Notes: The individual door trigger wires are at the underdash fuse/relay box. The LF door is green, RF door is lt. GREEN/ red, LR door is GREEN/ YELLOW, and RR door is GREEN / WHITE. Use all four wires and diode isolate each.
Dome Supervision GREEN/ red - interior light switch on dash
Trunk/Hatch Pin blue/yel, blue/org (tailgate) - MICU
The back window pin switch is blue/orange (-) at the instrument cluster, 14 pin plug, pin B3.
Hood Pin
Trunk/Hatch Release
Power Sliding Door N/A
Factory Alarm Arm WHITE/ red - driver door module in door
Factory Alarm Disarm white - driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer blue ac PCM, connector A, pin 28
Notes: The PCM (Powertrain Control Module) is behind the passenger side headlight.
Can also go to any ignition coil and use the wire that is NOT BLACK/ white or black.
Can also go to any fuel injector and use the wire that is NOT yellow/black.
Wait to start N/A
Brake Wire WHITE/ black + brake pedal switch
Parking Brake GREEN/ orange - parking brake switch
Horn Trigger GREEN/ YELLOW - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Not Available
Be careful whose advice you buy, but be patient with those who supply it.
